G35 window (not your usual window problem)
Old May 2, 2012 | 09:30 PM
CHUBBZ510's Avatar
CHUBBZ510
OG SKYWALKER
Default G35 window (not your usual window problem)
hey everyone,
i know there are a lot of threads regarding the driver window issue with these cars, and yes i know i need a new motor i have had it checked out before.
it use to work slightly and sometimes i use to tap on the door when it got stuck and it worked again.
Now my issue is that the window is now completely stuck. its open about half way now my issue is i have to go on a 5 hr drive tomorrow night and i was wondering if there is a way to open the door panel and roll or pull the window up manually? i just dont have time to go to a shop now and i need to make this drive down to LA.
if there are any solutions let me know.
thanks everyone!
Old May 4, 2012 | 04:37 PM
superchargedg's Avatar
superchargedg
Damn Noobs
With an electric window and its regulator assembly you cant just force or manually roll up the window.If you were able to you would def kill the regulator assembly and that can only be bought at the dealer...and its not cheap like the motor is.
Old Aug 22, 2012 | 07:56 PM
13ino13's Avatar
13ino13
Really? Because I just found pages of regulators for 80-120 bucks..
Old Aug 23, 2012 | 09:10 AM
vegaseric's Avatar
vegaseric
You might be able to remove the motor and clean it out. You might as well replace the motor at that point though... it's about a one-hour/beer job.
Old Sep 2, 2012 | 10:24 PM
bigbenarmy's Avatar
bigbenarmy
Freedom of all, the lion arches is a pirate city located on the Kryta, where buildings once most of the capsized vessel, as well as other old navigational equipment recycling. Was once the center of power in Kryta as well as major trading city, cheap guild wars 2 gold lion arches the aure flood rises from the sea to destroy. By mercenaries and pirates after the waters receded, the reconstruction, and have saved so far here is the headquarters of the Association, as well as the cultural melting pot of the soldiers of all nationalities. Lions arches one leading to the entrance of the realm of the fog, all races can use it. Today only a few known entrance. One is inside the tomb of the kings of the department has been sub-Pa Dayton to corrupt, and it seems in the end of the Long branded Canyon. Another entrance in the TFL Tyne Tomb, located in the territory of Charles depths in warfare Order of the islands are still capable of find another entrance, click here to buy gw2 gold but being sunk in the floods triggered by the department in the wake of war Dansu. Players battle will probably be held in the city, and may with Lions Gate arch arena has been connected, criminals can choose to fight to get freedom possible, rather than stay in jail wasting away.
Old Sep 4, 2012 | 02:25 PM
onthe3rdday's Avatar
onthe3rdday
FYI you can manually roll the window up if you have the patience and small hands. Keep the motor attached to the regulator, remove the motor cover (3 extremely small screws) and manually turn the assembly that you see once you remove the motor...3 months too late, I know but this should help others in the future. I had to do this after my window was stuck halfway down after a black friday sale last year.
Old Sep 5, 2012 | 08:40 PM
Rocknthehawk's Avatar
Rocknthehawk
You can remove the motor and use a 3/8 drive ratchet to manually raise the window. then tape it up or however you choose.
Uriyo_
Sep 8, 2021 08:46 AM
