How to adjust window? doesn't seal at 60mph and has a little rattle
Old May 26, 2016 | 12:50 PM
JRP350z's Avatar
JRP350z
Default How to adjust window? doesn't seal at 60mph and has a little rattle
07 g35 coupe
The window seems to go up and down level, and adjusts properly when door is opened closed but at over 60mph the top of the window toward the rear of the car goes outside of the lip on the roof creating a 1/8-1/4" gap. also the front of the window rattles against the front window guide rail whenever its fully closed or open.
Any tips on where to start adjusting the window to fix these issues?
Old May 26, 2016 | 03:27 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Are you missing some of the bolts on your metal frame that holds the window track? I took mine apart when I needed to replace my window motor. Nothing seemed to be adjustable up in their.
Old May 26, 2016 | 07:37 PM
JRP350z's Avatar
JRP350z
Ill check those again, but pretty sure i went over every bolt when i took the door panel off to change speakers and they were all tight.
draft
Suspension
May 8, 2016 06:06 AM
vp85
May 5, 2016 09:04 AM
Reece350z
Apr 28, 2016 06:49 AM
sag
Apr 27, 2016 07:50 PM
