Replacing wheel bearing Help!?
Old Sep 10, 2017 | 03:35 AM
basedgod_11's Avatar
basedgod_11
Newbie
Default Replacing wheel bearing Help!?
So I've been trying to replace my rear wheel bearing. And ran into a issue I've taking everything off. I unscrewed the 4 bolts behind the axle. I pulled the hub assembly with a joint puller. So it's just the bearing assembly on there. So all I have left to do is remove the bearing assembly. So I'm wondering if anyone ran into this problem before and maybe someone can give me some tips. Or a second opinion but, the bearing assembly is like seized on there and I can't get it to come off. It's not holding on by the bolts because I removed them. I've tried everything. Sprayed tf out of it with rust repellent, hitting it as hard as I can with a mini sledge hammer, try to chisel it with a air hammer, I've also try to put one of the bolts back in and punch it with the air hammer and that thing will not budge. It's like it's welded on there. I've ran out of ideas and don't know what to do. My last idea is to maybe cut it with a angle grinder or something smaller and cut it in 4s and try to hit it with a sledge hammer. I don't know if it's a good idea. I need a 2nd opinion. I would really appreciate the help. I need to get the car back together before I go back to work tomorrow.
hndumafia
Aug 4, 2019 10:16 PM
sjtomcat
Sep 28, 2016 07:58 PM
pfregeolle
Apr 14, 2012 03:01 PM
