help with aiming low beam on 2005 G34 with new assembliies
Old Today | 07:16 AM
CFAUVEL's Avatar
CFAUVEL
Default help with aiming low beam on 2005 G34 with new assembliies
I bought new light assemblies after Hurricane Milton (got a branch through the left side assembly)
After R&R the assemblies I went to adjust the beams. Using a No 2 Phillips and following directions as to which way to turn I was able to get the left beam to be correct.
But sadly I cannot get the right side to go UP...down is no problem. On the UP direction it just clicks....
At this point I have to remove the bumper et al, and slide the assembly forward to get a 6MM ratchet on the hex that actually turns the screw that brings the beam up or down.
If you have ANY other suggestions without resorting to removing the whole bumper again, I'm all ears.
Old Today | 07:22 AM
iideadeyeii's Avatar
iideadeyeii
The bottom one should raise and lower the beam. At least on my aftermarket one it was the lower one.
I think the top would be for angle, but I did not touch it.
Mine are a little different than yours though.
Old Today | 07:56 AM
iideadeyeii
My experience with aftermarket 350z headlights is that NONE of them have good light except the oem replicas. I've tried 4 different aftermarket headlights over the past 10 years and none of them could give a usable correct beam with HID's
I have these and they are great. I had to adjust the beam up a lot from the factory setting, but they are great quality. I had use the aftermarket ballast o-ring instead of the one that came with the headlight to seal them to the housing.
https://shorturl.at/2w76n
I recommend getting actual Phillips D2R's and aftermarket oem type ballasts (about $150 for all ) I also did order a better connector for the ballast as the one that came with the headlights kept pushing the wires out and had to break apart part of the white shield inside the connector for it to work properly.
Amazon Amazon
Old Today | 07:57 AM
iideadeyeii
I just realized this is g35 not 350z
Old Today | 08:19 AM
CFAUVEL's Avatar
CFAUVEL
https://www.amazon.com/dp/B0D7PM8GQM...fed_asin_title
I indeed bought OEM Looking aftermarket ones. and moved my ballast over to the new assemblies....and I indeed bought real phillips D2Rs.
I've been playing around with the old assembly that wasn't broken by a branch.....the lower adjustment that is designed for the phillips head screw driver....actually moves the lower bulb...THAT IS THE HIGH BEAM....maybe if you move the lower, the upper moves......but on the old assembly there is a blocked off adjustment screw that is capped with a piece of plastic held on by screws....under that cap there is another hex head that moves the upper bulb, the low beam.....if I turn THAT hex, I can see the upper bulb move up and down.
it looks like the new assemblies have the same type of cap....I will try to remove the cap without removing the bumper and assembly.
Old Today | 08:35 AM
iideadeyeii
I would assume it's this
David_z33
12-03-2018 11:02 PM
technopimp
08-09-2018 08:22 AM
Liquidonyx
Exterior
03-10-2012 05:19 PM
xw34x
12-20-2003 07:47 PM
Quick Reply: help with aiming low beam on 2005 G34 with new assembliies
