Gauge Pods
Old Mar 7, 2004 | 12:08 PM
booger's Avatar
booger
Default Gauge Pods
Does any one make a gauge pods for the G35 ? Im just about ready to order the Vortech in the next week or so . Also ...what gauges do you think I should get.....I know...Wide ban o2 gauge and Boost gauge.......but should the other be....EGT ?.....Fuel Pr. ? Whats the more inportant to keep track of ?
Old Mar 7, 2004 | 12:44 PM
teh215's Avatar
teh215
Search
Old Mar 7, 2004 | 03:10 PM
TXREFI's Avatar
TXREFI
Talk with David at 350Zforum / G35 parts He is getting a mold with pods in pillar.
Old Mar 7, 2004 | 03:16 PM
Eagle1's Avatar
Eagle1
Default Re: Gauge Pods
Here is a link to what I did with my G35
http://www.imagestation.com/album/?id=4287816943"><IMG SRC="http://www.imagestation.com/images/is/community/this_album_button.gif
Old Mar 7, 2004 | 06:09 PM
booger's Avatar
booger
Default Re: Re: Gauge Pods
DAM eagle you sure have every gauge you could think of there .I have been thinking about putting a couple of gauges in the cubby hole where the navigation goes and staying stealth .I know they have dual gauges some where but cant find them .Wanted to put a wide ban o2 gauge and a dual gauge...maybe....boost and EGT ...or boost and fuel pr.
Old Mar 8, 2004 | 04:52 AM
Eagle1's Avatar
Eagle1
Default Re: Re: Re: Gauge Pods
If you want to go inside the nav cubby you are going to have to go 52mm diameter. The 60's are not going to fit.
Jeff at Performance Nissan has the AEM wide band 02 gauge and really likes it.
There is room for two in the nav cubby, three would be too snug I think.
If you are going to be running FI then I would put the air/fuel and the boost there, right under your nose.
The others are to monitor but are not as critical. I wanted the J&S Ultrasafeguard unit so I had to get creative about how to mount it, and the desire to have it overcame my initial focus on putting it inside the nav cubby as well. Compromise is sometimes necessary. But the molding looks OEM so it at least does not jump out at you.
The other gauges on the map box are canted towards the driver for easy read, and they are, from left to right, EGT, Fuel Pressure, Oil Pressure, and Water Temp.
I make a point of just glancing over frequently, especially during different load conditions, to get the feel for what the car is doing under varying circumstances. That way, when I do have a concern, I know what they should be looking like if everything is the way it should be under any and all circumstances.
Good luck.
Old Mar 8, 2004 | 05:14 AM
booger's Avatar
booger
I dont think Im going to push the limits on the SC ...so I think I will put them in the nav. cubby...and go with A/F wide ban and a dual digital gauge...boost and fuel pr...or boost and EGT . ....Did you make that 3 gauge pod your self ? nice job
Old Mar 8, 2004 | 05:29 PM
Sam56n's Avatar
Sam56n
i just got a voertech intalled
i got two gauges in individual pods under the steering wheel on the righ side (fule pressure and boost)
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
