How many HP can I expect
Old Mar 11, 2004 | 06:10 PM
blueg35c's Avatar
blueg35c
Default How many HP can I expect
from these mods:
Z tube with K&N filter
JIC Y-PIPE
Kinetic High Flow Cats and Plenum
UR Crack Pulley
Old Mar 11, 2004 | 11:50 PM
Splurt's Avatar
Splurt
I don't own a G, but if I were to sum it up with Z gains I'd say u'd get a nice 4~6 rwhp from the crank pulley all thru the powerband. I definately noticed that diff when I dynoed my car. From Kinetix plenum/cats I'd assume you'd get around 6~10 rwhp but definately more area under the powerband. It's a little conservative a guess since there really isn't much info out on them yet. I have no idea about the Z tube or Y pipe since I went true dual. I hope this helped. Take it ez!
Old Mar 12, 2004 | 06:49 AM
Gsedan35's Avatar
Gsedan35
Default Re: How many HP can I expect
Originally posted by blueg35c
from these mods:
JIC Y-PIPE
UR Crack Pulley
You'll get gain's, but until you pair the Jic Y-pipe with a 80mm system down stream, your holding it's full benefit back. Suddenly going from 80mm to 65mm is the problem. Kinda hard to say what you'll get since people tend to be all over the map come dyno time. If you have a good day at the dyno you'll get 15-20hp.
Old Mar 13, 2004 | 08:57 PM
350Z 2+2 ???'s Avatar
350Z 2+2 ???
from these mods:
JIC Y-PIPE
UR Crack Pulley
The Kinetix tandem was good for 17hp on the dyno that I saw. The others mods should add a couple of HP each, but I think that CRACK PULLEY should be good for a "butt-load".
Old Mar 14, 2004 | 07:22 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
i say 20-25
May 30, 2017 03:28 PM
gc350z03
Oct 28, 2016 05:00 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
