What spring will give the lowest drop??
Old Apr 22, 2004 | 01:14 PM
Import-Tooner's Avatar
Import-Tooner
Default What spring will give the lowest drop??
So... I don't want to spend the money coil overs right now. Mostly becuase I don't have it. I want to lower my car about two inches or so. What is a descent spring that will give me that much drop or around there??
Here is what I've found so far:
Tein S tech 1.2 front .9 rear
Tein H tech .6 front .6 rear
Eibach pro kit 1.1 front 1.0 rear
And I think Intrax is 1.8 front and 1.8 rear
Is there any that I may not know of?
Old Apr 23, 2004 | 06:17 AM
bwzabodyn's Avatar
bwzabodyn
Sprint Springs - 1.75" all around - the same springs that Ducatiguy from G35driver.com uses - they are very affordable also... (~$125) - you will definitely need a camber kit though to get the alignment in the rear back to spec...
Old Apr 23, 2004 | 06:19 AM
NismoGCoupe's Avatar
NismoGCoupe
Default Re: What spring will give the lowest drop??
you can look into the tanabe, KG/MM they have a pretty low drop
Old Apr 23, 2004 | 07:08 AM
tig488's Avatar
tig488
i have kgmm and i want to say they lowered mine about 1.5 inches, but they cost a little more than most other springs. but the ride is excellent!
Old Apr 23, 2004 | 08:17 AM
Import-Tooner
Does tanabe make the kgmm springs?
Old Apr 23, 2004 | 02:57 PM
Import-Tooner
Well, I decided to order tein s-tech springs. I'll take some pictures after I'm done so you can see the difference.
Old Apr 25, 2004 | 09:09 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you are looking at springs that lower you alot...
i would highly sugest the TEIN Basic's...
Fully adjustable coil over set up... you can drop to 3.2" and 3.0" onthe G...
install cost is thesame as just doing the springs...
