Removing badges??
What does it take to remove the badges on the trunk? I have seen a couple that have been done and I've gone back forth but I think I'm going to do it. It just looks real clean.
use some fishing line or dental floss to get the emblems off.. slide the line behind the emblem and they will come right off.. use some bumper sticker remover to take off the tape residue.
be careful, the nissan emblem has holes behind it, wo you will need to put something else there or have a body shop plug and paint it...
Originally posted by Import-Tooner
so.. there are holes under the infiniti symbol?
First off us G35s have no holes anywhere. All the emblems on the back are stuck with 3m double sided adhesive.
First use dental floss to get the imblems off.
After this you should see grey sticky stuff left over. Use either WD-40 or goo gone to take this all off. This will take some time so be patient.
If you have any questions search www.g35driver.com
Originally posted by g35thanh
i didnt need to use anything. just pry it off with your fingers. it comes off pretty easy.
Removed mine .
on a warm day with rear trunk in direct sunlight for a few hours , the emblems will come off more easily with fingers or floss. Heat softens the goo and makes it much easier. A hair dryer also works.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
