Negative Camber After Mounting 19s??
Old Jun 22, 2004 | 02:18 PM
g35thanh's Avatar
g35thanh
Default Negative Camber After Mounting 19s??
My rear tires are noticeably tilting in now after mounting 19s...is this normal?
Old Jun 22, 2004 | 02:47 PM
moog's Avatar
moog
The car already has a bit of negative camber already from the factory. It's just more noticeable now that you have bigger wheels.
I noticed it as well when I mounted my 20s
Old Jun 22, 2004 | 07:57 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
is your car dropped at all? if it is, you may have to get toe and camber adjustable bars. your tires will thank you in the long run. if you jus' put on your springs, let 'em settle out for a month or so before you get an alignment.
n1cK!
Old Jun 22, 2004 | 08:16 PM
g35thanh's Avatar
g35thanh
no, i 'm stock.thats why i was wondering why it has negative camber
Old Jun 22, 2004 | 09:08 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
ah, well in that case, moog's right.
n1cK!
ps-adjustment arms will still help, significantly.
Old Jun 22, 2004 | 09:14 PM
jesseenglish's Avatar
jesseenglish
The fact that you put 19" wheels should have no effect because the diamater of the tire is the same. I think it looks more negative because your tires are more than likely much wider than stock so it exaggerates it.
Old Jun 26, 2004 | 02:30 PM
AXA_G35's Avatar
AXA_G35
just lower your car...it'll fix then...
Old Jun 26, 2004 | 03:04 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
lowering your car actually makes it worse. lowering it about 1.5" throws the geometry all out of whack. you'll definitely need some adjustable rods then, even the front a-arms (really expensive).
n1cK!
Old Jun 27, 2004 | 10:11 PM
AXA_G35's Avatar
AXA_G35
n1cK!
yeah, i'm definitely in need of rear camber arms...
Old Jul 4, 2004 | 08:51 PM
g35thanh's Avatar
g35thanh
will this cause my tire to prematurely wear faster?i'm thinking about lowing it with tein h techs, but i dont want the tires to wear out too fast. especially since im rolling on 19s...
thanks guys
Old Jul 4, 2004 | 11:35 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
thanks guys
yes, it will definitely cause your tire to preaturely wear on the inside, unless you fix the camber. toe will affect straight line stability and cornering (camber also affects cornering).
n1cK!
Old Jul 5, 2004 | 08:10 AM
g35thanh's Avatar
g35thanh
should i just wait till i lower it and get one or do it now?damn, now i'm afraid if i do lower it with h techs, i would need a camber kit.
Old Jul 6, 2004 | 08:22 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
G35 Coupes rear camber is more noticible then the Z... you dont really notice it as much until you really look, and you really look when you put on new wheels!
Old Jul 6, 2004 | 12:32 PM
g35thanh's Avatar
g35thanh
^^ yea, thats probably true. i just dont want it to eat up my tires.
Old Jul 6, 2004 | 01:36 PM
myz8a4re's Avatar
myz8a4re
factory settings (camber) on my z was eating the inner tire edge in the rear from the amount of neg camber. i have a less aggressive camber setting now after my car is lowered as opposed to factory settings to eliminate the need to replace my tires every 10k miles.........
-justin
Old Jul 6, 2004 | 05:20 PM
g35thanh's Avatar
g35thanh
-justin
how did you have a less aggressive camber setting after lowering your car?
HoBrahYouStink
Jun 24, 2016 10:58 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
