installed autometer tachometer but prolblem.
Old Aug 25, 2004 | 02:54 PM
toylee's Avatar
toylee
Default installed autometer tachometer but prolblem.
hey guys, i just installed tachometer. i connected to ecu pin62 yel/red. it is working but it read only half of rpm... when 3000rpm tacho reads only 15000rpm. i followed instuction from autometer. i cut the brown wire for 6cylinder. and i tried other loop too. but still same. need help anyody...
Old Aug 25, 2004 | 03:10 PM
lorinserbenz's Avatar
lorinserbenz
Default Re: installed autometer tachometer but prolblem.
Pin 62 may not work for that kind of tach. What cylinder settings do you have? Does it have an option for ONE cylinder?
Old Aug 25, 2004 | 03:26 PM
toylee's Avatar
toylee
Default Re: Re: installed autometer tachometer but prolblem.
no instruction has for 8,6,4cylnder... any idea. shoud i connect to coil. i found some information from other forum. it says connect to any ignition coil wires but not black or white/blue. but i have no idea where located ignition coils are...
Old Aug 25, 2004 | 09:56 PM
toylee's Avatar
toylee
Default Re: Re: Re: installed autometer tachometer but prolblem.
i found ignition coils. i connected but still rpm doesnt match. no idea...........
Old Aug 26, 2004 | 01:50 AM
toylee's Avatar
toylee
hey guys look what i found after long search...its been three day installing autometer lunar tachometer on g35 coupe. http://www.martelbrothers.com/custom...ductid=MSD8913
instruction from msd http://www.msdignition.com/pdf/8913_tachdriver.pdf
we should try this one. i sent email to msd. lets see what happen. i will let you know.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
