Forced Induction kits...
Old Sep 1, 2004 | 09:43 AM
xXVanquishXx's Avatar
xXVanquishXx
Default Forced Induction kits...
Are they are turbo kits for the G35 with automatic transmissions? I don't won't to get a super charger because the hood has to be replaced. So far, Greddy's turbo kit only works on the 6MT.
Thanks.
Old Sep 1, 2004 | 10:08 AM
AXA_G35's Avatar
AXA_G35
i think the PE(Power Enterprise) kit works on both auto and manual....i just saw an auto 350Z with the PE TT kit.
Old Sep 1, 2004 | 02:07 PM
Import-Tooner's Avatar
Import-Tooner
There are a few super charger kits that don't require you to change the oem hood. Allthough I myself want the greddy tt kit
Old Sep 1, 2004 | 02:23 PM
GMADD's Avatar
GMADD
Do I need to upgrade the internals, pistons, rods ect. if I go FI ?
I want 400 whp & wtq.
Old Sep 1, 2004 | 03:20 PM
AXA_G35's Avatar
AXA_G35
it's always a good idea to upgrade your internals...and there are many parts available for our cars...
i think GReddy advertises as we don't have to upgrade as long as we run it at the stock boost...which should be darn close to 400whp....
Old Sep 5, 2004 | 01:29 PM
GMADD's Avatar
GMADD
The thing is that I have an automatic g35 coupe, so I don't think the Greddy kit will work for me.
Have you heard of Speed Force Racing ?
They have a kit for the auto but I don't know much about them do you or anyone else ?
Thanks,
if I get a turbo I will be upgrading the internals.
Old Sep 6, 2004 | 09:17 PM
SSR Engineering's Avatar
SSR Engineering
Thanks,
We have turbocharged a few automatic G35s, and exceeded 400WHP without problems to the engine, or transmission.
Old Sep 6, 2004 | 11:12 PM
shiva's Avatar
shiva
As I remember, you didn't retard timing...I don't mean to question your expertise but I don't think that was a very safe setup.
Old Sep 7, 2004 | 03:43 AM
booger's Avatar
booger
The only SC that needs a new hood is the STILLEN SC
Old Sep 7, 2004 | 08:17 AM
GMADD's Avatar
GMADD
Thanks for the reply,
Can I use the Greddy e-manege with this kit or do you supply someting like that ?
Thanks again !
Tasso -
Old Sep 8, 2004 | 06:58 AM
G35SC T.T.'s Avatar
G35SC T.T.
pm's sent
Old Sep 12, 2004 | 07:10 AM
TXREFI's Avatar
TXREFI
Default Re: Forced Induction kits...
You can use the Greddy Kit on a G35 5AT, I know I did it 5 months ago. I used the e-manage, although I just took the e-manage off and added new black box so I can retard the timing. But the stock greddy system produced 345 HP & 375 TQ at the rear wheels, pulls very strong.
Thanks.
Old Sep 12, 2004 | 12:22 PM
GMADD's Avatar
GMADD
Default Re: Re: Forced Induction kits...
I also have a g35c auto.
Do you have any problems with the tranny ?
I'm going turbo also in the spring but now I'm not sure if I'll get the Greddy or the PE.
Did you have problems installing it ?
I spoke with Greddy and they said I need a to upgrade the tranny first, did you ?
Thanks !
Tasso -
Old Sep 12, 2004 | 01:33 PM
TXREFI's Avatar
TXREFI
Default Re: Re: Re: Forced Induction kits...
I just had Level 10 rebuild the value body, but I did it to get stronger, harder shifts, not that I needed any tranny work.
For the first few thousand miles I did not have any problems with the stock tranny, I only had the value body rebuilt for stronger shifts.
Thanks !
Tasso -
