350Z springs on a G?
Old Oct 7, 2004 | 09:11 PM
SponGer's Avatar
SponGer
Default 350Z springs on a G?
Decisions, decisions...can't decide what springs to get.
Anyone here put Z springs on their G? If so, what brand and model? I was thinking about getting S-Techs for a 350Z. Any input?
Old Oct 9, 2004 | 07:42 AM
Brando's Avatar
Brando
Default Re: 350Z springs on a G?
Depends on what you want....but I have researched and am going with the Tein 350z H techs.
Old Oct 9, 2004 | 10:18 AM
neffster's Avatar
neffster
Default Re: Re: 350Z springs on a G?
Me too. Should be installed this coming Thursday or Friday.
Old Oct 9, 2004 | 12:27 PM
SponGer's Avatar
SponGer
Thanks for the input. Why the Z H-Tech's and not the S's? Isn't the drop for the 350Z less than the G35?
Old Oct 9, 2004 | 07:45 PM
SponGer's Avatar
SponGer
Neffster, read your thread in g35driva. Z springs will give the G an additional 1/2" drop.
Old Oct 9, 2004 | 09:24 PM
tcfool's Avatar
tcfool
I put the RS*R springs for the 350Z on my Girl and the drop is perfect......
TC
Old Oct 9, 2004 | 09:37 PM
G352NV's Avatar
G352NV
Ive got tein H techs for a Z on my G. Very happy with them and the ride.
Old Oct 11, 2004 | 07:00 AM
neffster's Avatar
neffster
Scrape much with that setup?
Did you do a before and after measurement on the drop?
What are your current alignment specs?
Thanks!
Old Oct 11, 2004 | 11:07 AM
Airs414's Avatar
Airs414
TC
Im thinking of buying the RS*R's for the z for my g. can you tell me what the actuall drop is and if you have camber issues. thanks a lot.
Old Oct 12, 2004 | 11:24 AM
loismustdie's Avatar
loismustdie
i got RSRs for the Z on my G a few weeks ago (thanks to street image)... springs settled a bit after a while, came out with about a one and a quarter finger gap all around.
scrapes a lot, drives me kinda nuts... but I love the way it looks.
Old Oct 12, 2004 | 12:24 PM
RedLine6mt's Avatar
RedLine6mt
Good question.
I too am in the market for springs and was also curious about the difference.
Are the Z springs also stiffer than the springs made for the G? I'm weary about putting Z springs on because it should be designed for the weight distribution of the Z? right?
Old Oct 12, 2004 | 03:03 PM
neffster's Avatar
neffster
Originally posted by RedLine6mt
Good question.
Here is a little bit of info for you to sort through courtesy of a cut and paste from a post from Gsedan35 on G35driver.com
Stock Coupe 6MT Spring rates are the same rate as the 350Z spring and the sedan with the sport suspension.
314/342
Here are the spring rates in comparision to all known lowering spring/coilover product made for the Z33/CPV35/V35. If a product is not listed, that maker refused to give out the info.
Eibach's as noted (first number is the softer initial rate, followed by the higher final rate)
350Z 296/384 front 316/421 rear
G35c 229/337 front 274/463 rear
G35s 259/334 front 359/413 rear
RSR 350Z springs (just a wee bit progressive F&R, maybe one coil is progressive)
345/417 F+10% R+22%
Transfers +12% roll stiffness to rear
RSR G35 coupe springs (progressive front and rear)
315/315 F+0 R-8%
Transfers +8% roll stiffness to front
Hotchkis 350Z springs (linear springs)
340/330 F+8% R-3%
Transfers +12% roll stiffness to front
Tein S-tech 350z (fronts are progressive, rears are linear)
386/402 F+23% R+16%
Transfers +7% roll stiffness to front
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
Tanabe GF210 Series 350Z
336/375 F+7% R+10%
Transfers +3% roll stiffness to rear
Tanabe NF210 Series 350Z
314/353 F+0 R+3%
Tanabe NF210 Springs G35 COUPE
297/336 F-5% R-2%
Tanabe DF210 Springs G35 COUPE
308/353 F-2% R+3%
Transfers +5% roll stiffness to front
Tanabe NF210 Springs G35 SEDAN
297/269 F-5% R-21%
Transfers 17% roll stiffness to front
Tanabe DF210 Springs G35 SEDAN
286/280 F-9% R-18%
Transfers +9 roll stiffness to rear
Kg/mm springs 350Z
DR21 super sport 15mm drop
246/398 front 252/409 rear
Kg/mm springs 350Z
DRacing 30mm drop
252/454 front 252/482 rear
Espelir coupe springs (the U.S. importer recently changed specs, I do not believe the newly listed specs are correct, since the new one's are extreamly high. And when I called the company to ask if the springs are linear or progressive, they told me Linear, turn's out they were absolutley wrong, they are in fact progressive. I show the old specs for those reasons, take it with a grain of salt, same thing for the 350Z fitment)
409/460F F+30% R+37%
Transfers +7% roll stiffness to rear
Espelir 350Z springs
381/460 F+22% R+37%
Transfers +15% roll stiffness to rear
Tein Flex
672/672 F+114% R+98
Transfers +16% roll stiffness to front
Tein Flex JDM specs (can be special ordered est 6-8 weeks delivery)
560/560 F+78% R+64%
Transfers 14% roll stiffness to front
Tein Basic
504/504 F+61% R+43%
Transfers +18% roll stiffness to front
Tein CS (Monotube)
392/392 F+25% R15%
Transfers +10% roll stiffness to front
Nismo S-tune (uses progressive springs, especially in rear)
350Z/G35 Coupe
448/504 F+43% R+48%
Transfers +5% roll stiffness to rear
Nismo S-tune (uses progressive springs)
G35 Sedan
347/342 F+10% R+0%
Transfers 10% roll stiffness to front
Buddy Club Racing Spec coilover (Monotube)
748/280*
(very likely run's rear springs on the dampner body and not at the oem rear spring location)
Jic Flta-2 350Z fitment (Monotube)
560/672 F+78% R+98%
Transfers +20% roll stiffness to rear
Jic Flta-2 G35 coupe (Monotube)
560/560 F+78% R+64% $1750
Jic Flta-2 G35 sedan (Monotube)
504/392 F+61% R+15%
Transfers +46% roll stiffness to front
Cusco Zero 1&2
560/392 F+78% R+15%
Transfers +63% roll stiffness to front (no they do not run their rear springs on the dampner body, oem location, seen them on the car with my own eyes.)
HKS LS+ (rear springs are progressive)
496/440 +58%front +29%rear
transfers 29% roll stiffness to the front
HKS LS G35
448/336 43%front -1%
transfers 44% roll stiffness to the front
HKS LS 350z
448/448 43%front +31%
transfers 12% roll stiffness to the front
HKS II 504/504 +61%front +47%rear $1600
transfers 14% roll stiffness to the front
KW coilovers Variant's 1,2&3
Variant 3's are noteworthy as the only known coilover for these cars where the dampners are adjustable for compression and rebound independently. They also differ in using progressive springs front and rear
Front: 485lbs to 525Lbs Rear: 240Lbs to 548Lbs
D2 Racing Coilovers (Monotube)
840/728 F+168% R+113% (wee bit stiff eh, the recommended rate to)
Transfers 55% roll stiffness to front
Basically the increased roll stiffness to the front of the vehicle will add more understeer. The percentages which are positive will have a more harsh or more stiff ride than stock. Negative numbers will be softer. The farther away the spring rates get from zero, the faster the stock shocks will wear out (unless you are considering coilovers).
As you might notice, the Tein H-Techs for the 350Z add the least amount of additional understeer (w/o adding to oversteer) keep the springs rates closest to stock, allow a 0.8" drop in the front and a 0.7" drop in the back for a G35 and a drop of 0.3" in the front and 0.2" drop in the back for a 350Z. They also should not wear out the stock shocks too fast as the spring rates are mildly more stiff than stock, yet you get a nice subtile drop. By adding them I'm hoping to stay within the stock camber and toe ranges, thus not having to add camber/control arms and toe bolts...
Old Oct 12, 2004 | 09:32 PM
SponGer's Avatar
SponGer
Everyone, please post pics of your set up.
Old Oct 13, 2004 | 05:39 AM
RedLine6mt's Avatar
RedLine6mt
Originally posted by neffster
Neffster - Thanks for the post! It was a lot of help!
Old Oct 13, 2004 | 05:48 AM
ExtaZ33's Avatar
ExtaZ33
What do stock Z springs do for a G? Anyone know the effect?
Old Oct 13, 2004 | 03:50 PM
neilis300's Avatar
neilis300
so... if i got tein basic for a z my g35c would be 0.5 lower than a g35 with a tein basic g35c setup( for the max drop height)?
Old Oct 13, 2004 | 04:00 PM
enzo-g's Avatar
enzo-g
about two months ago, i installed tanabe GF210 made for the Z. it's looks great and the spring rate is just what i wanted--stiffer than stock. the drop is about 1.5" even though it says 1" on the box.
here are some pics:
Old Oct 13, 2004 | 08:39 PM
SponGer's Avatar
SponGer
Enzo, looks sweet. Admired the drop when you posted pics a month or so ago.
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
