New Dyno NUmbers After Header Install
Old Dec 7, 2004 | 07:08 PM
  #41
hfm's Avatar
hfm
Last post.
I won't comment about this kind of thing again. Nothing but grief in doing so, even if you are trying to be helpful.
Dan
Old Dec 7, 2004 | 08:11 PM
  #42
deviant1's Avatar
deviant1
Here's a pic to help clear up the confusion with the different scales used on those dyno plots. Still looks like some pretty nice gains across the board with the addition of the Topspeed headers.
Old Dec 7, 2004 | 08:23 PM
  #43
Z BOY's Avatar
Z BOY
nice plotting...makes it much easier to compare and see the gains.
Old Dec 7, 2004 | 08:26 PM
  #44
350zWarz's Avatar
350zWarz
thanks...i was to lazy to do that, just eyeballed it...looking forward to getting mine on soon
Old Dec 7, 2004 | 10:15 PM
  #45
Z BOY's Avatar
Z BOY
off topic: go here to join jet-hot header coating gb:
http://www.350zmotoring.com/forums/s...threadid=18033
Old Dec 8, 2004 | 03:20 AM
  #46
zachcrosen's Avatar
zachcrosen
Originally posted by hfm
I took this as a dig:
From what I've seen the people at Z1 know what they're doing. Saying that Z1 don't have a clue looked like a dig. If you have a good relationship and I misunderstood, then you obviously don't owe an apology.
To clarify, Z1 specializes the the 300ZX. They have just begun working on the 350z. With that in mind, they are very new to the new technology in the 350s. As with all new things, it takes time to learn the vehicle inside and out and what it may or may not do.
Old Dec 8, 2004 | 03:20 PM
  #47
zachcrosen's Avatar
zachcrosen
Thanks Deviant1 for the analysis. I guess I am better than I was before the header install. Your lines make it a lot easier to analyze my dynoes.
I sent an email to Technosquare to see what they thought about my problem I am experiencing. Here is what Brian had to say:
Hi there Zach. As biased as it may sound, this is probably the ECU reacting and you will need a reflash. =) The 2004 and 2005 ECUs are a bit more advanced than the 2003 as the computer reacts a lot faster to changes done to the car. They work quicker to emit less emissions so they pull timing a lot more drastically and they richen up the car if it's too lean. So as many mods as you put on the car, they'll all be negated at the end and you most
likely will lose power. With our reflash, we take care of the ECU correcting the car to get to 10.5 AFR and raise it to 12.5. We also do the rev limiter, the speed governor, 100% WOT, altered fuel and timing maps. The price is $595. One thing is that we can't do all ECUs just yet. We can only do the R4 and R5 versions that will be written on the ECU if you look at it. Please refer to this page for more information. http://www.technosquareinc.com/2004.htm
Brian Wong
22521 S. Normandie Ave
Torrance, CA 90501
Email: brian@technosquareinc.com
Phone: (310) 787.0847
Fax: (310) 787.0948
What do you guys think
Old Dec 8, 2004 | 05:30 PM
  #48
zzzya's Avatar
zzzya
It can be a pain sending the ECU back and forth to get it all "right" but when done you will see very positive results and technosquare is very quick about sending the ECU out ASAP. If you commit to getting it right, so will they. I overnighted my ECU out to them and they overnighted it back, if timed properly you could send your ECU out twice a week until it is where you want it.
Old Dec 8, 2004 | 05:44 PM
  #49
zachcrosen's Avatar
zachcrosen
Yeah, but doesnt that get VERY expensive sending it out that much??
Old Dec 8, 2004 | 06:53 PM
  #50
Z BOY's Avatar
Z BOY
what about a gb for the reflash???
why does it need to be reflashed more than once???
Old Dec 8, 2004 | 06:54 PM
  #51
zachcrosen's Avatar
zachcrosen
Good question. You are all about the GB thing. Get it hooked up!
Old Dec 8, 2004 | 07:01 PM
  #52
Z BOY's Avatar
Z BOY
zach,
i'm all about not paying $600!!! since you are already in contact with ts, would you be willing to ask about a gb, or would you rather i do it; i'll run it if ts makes us a good break. i'm definitely getting a reflash, but i have to get my headers coated and installed first.
Old Dec 9, 2004 | 03:21 AM
  #53
zachcrosen's Avatar
zachcrosen
zach,
Ill ask and let you guys now.
Old Dec 9, 2004 | 05:14 AM
  #54
ttsupra94's Avatar
ttsupra94
How do we know if we have an R4 or R5 version? I also dont see why you would need to send the ECU in multiple times. I think i am probably going to wait on headers until the spring when i will hopefully be doing a vortech and I will just get it tuned then with the software that comes with the vortech instead of getting a reflash. Zach might need the reflash since his numbers do seem to be pretty low.
Old Dec 9, 2004 | 07:49 AM
  #55
Zexy's Avatar
Zexy
Time to tune ASAP. This is your problem period.
Old Dec 9, 2004 | 07:51 AM
  #56
Zexy's Avatar
Zexy
Talk about tuning nobody has tried the AEM EMS??
If i had the bones, that's what i would definately go for.
Old Dec 9, 2004 | 12:37 PM
  #57
350Zenophile's Avatar
350Zenophile
I'm a bit confused. The dyno shows the AFR dropping from around 14 to 13 across the pull. This from what I understand is lean, i.e. dangerous and not good for power. But the ECU is doing good by trying to richen as rpms climb. With the reflash, is Brian from Technosquare saying that the AFR should actually do the reverse and rise across the pull from 10.5 to 12.5 at Redline?
I've also read some forum member stating his late model 04 is maintaining an AFR of 12.5 after similar extensive breathing mods without tuning. What gives? What is the X factor we are missing here?
Zach, do you know which ECU you have yet, R4 or R5?
Old Dec 9, 2004 | 01:41 PM
  #58
zachcrosen's Avatar
zachcrosen
I dont know which ECU I have but my build date on my Z was 7/03. It was the very first batch of '04s so it probably has the same ECU as the 03, but Im not for sure.
Old Dec 10, 2004 | 05:43 AM
  #59
350Zenophile
You might be interested in this thread:
https://my350z.com/forum/showthread....52#post1176552
Old Dec 10, 2004 | 07:38 PM
  #60
axxizzer's Avatar
axxizzer
my god
my old 5AT Z made 130more WHP than you...god I want that car back
