NISMO exhaust rattling/leaking
Old Dec 21, 2004 | 02:53 PM
jckolnturn's Avatar
jckolnturn
Default NISMO exhaust rattling/leaking
I am having a problem with my NISMO exhaust, i have a leak in the flex portion of the Y-pipe. It causes an annoying rattle at about 2,700 RPM's. I replaced the Y pipe once before because of this and now it's back. Anyone have any idea what's causing this?
Old Dec 21, 2004 | 03:48 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
did you put the spacers in for the crossmember?
Old Dec 21, 2004 | 03:56 PM
jimmy mitchell's Avatar
jimmy mitchell
my name is jimmy mitchell and you need to check the o2 sensor in your headers because im service mgr at kinston nissan and we had o2 sensor that kept tring to back out call me 7:30-5:30 at 1-800-280-1021 if you have any questions
Old Dec 21, 2004 | 04:34 PM
DavesZ#3's Avatar
DavesZ#3
^^^^^^^ WTF ????
Old Dec 21, 2004 | 04:36 PM
aws6000's Avatar
aws6000
The Nismo exhaust doesn't need spacers for the crossmember. Mine is nowhere near rubbing, so I would assume a correctly installed exhaust will not rub.
Not sure why the O2 sensors would be affected by installing the exhaust, but what do I know.
If it is leaking, you should be able to get it replaced fairly easily under warranty.
Old Dec 21, 2004 | 04:38 PM
Zexy's Avatar
Zexy
Another Nismo exhaust problem?
One of the only parts Nissan covers with warranty, and it seems to be the shittiest unit out of all in the market now.
Old Dec 21, 2004 | 05:57 PM
jckolnturn's Avatar
jckolnturn
It was replaced under warranty the first time and i would expect it to be replaced again, I haven't gone back yet. I wouldn't go calling it shitty just yet, i have a feeling something is causing it because i had the same problem twice. If you look at the system it is really well made, I've had mine on for several months now and it still appears new. As far as the O2 sensor goes I know the leak is in the flex section because I can see the braids rattle and the exhaust spit out but i'll check it anyway.
Old Dec 21, 2004 | 07:11 PM
aws6000's Avatar
aws6000
That sucks. I wonder if only the braided part can be replaced with something stronger. This is the first I've heard of the Nismo pipe leaking (which is why I went with Nismo over the Borla).
Old Dec 21, 2004 | 07:21 PM
jckolnturn's Avatar
jckolnturn
I don't want to alarm people i was just curious if anyone else had the problem, I still think it's a great exhaust system.
Old Dec 22, 2004 | 05:26 PM
Zexy's Avatar
Zexy
I say it got shitty because your thread is not the only one about it going bad.
Hope you get it fixed anyways
Old Dec 22, 2004 | 07:47 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
In the actual flex pipe?
Are your kenetix cats causing too much stress on the flex joints? Causing the Y-Pipe to crack in the flex Joints?
thats weird...
Old Dec 23, 2004 | 12:06 AM
jckolnturn's Avatar
jckolnturn
that's a possibility, i was afraid of.
Old Dec 23, 2004 | 04:51 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Sorry but your just wrong. Quite a few peope if not most have had to use spacers. Do a search there have been a # of threads on it. It seems he's got his problem narrowed down to the flex joints though.
Old Dec 23, 2004 | 08:36 AM
Jason@Performance
Performance Nissan
all the ones we hvae installed here did not need spacers unless a high flow cat was used...
I needed spacers on my NISMO exhaust with RT Cats... put my stock cats back on, no need for the spacers...
Old Dec 23, 2004 | 11:04 AM
jckolnturn's Avatar
jckolnturn
where do these spacers go and what are they supposed to help the exhaust clear? my exhaust isn't able to hit anything that i can see.
Old Dec 23, 2004 | 12:50 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I have stock cats (for now) and have not had any problems with the NISMO exhaust. I did not need spacers either but there was a thread on here detailing where to put them. Sounds like its more of an issue with the fitment of other parts than ther NISMO exhaust itself.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
