Installing K&N Filter - question
Old Nov 6, 2002 | 04:33 PM
LowFuel's Avatar
LowFuel
Default Installing K&N Filter - question
It seems to like to pop out of the stock filter-bracket. I noticed it says on the instructions to hold it in place with your index fingers as you drop it into the airbox. So I did that, and now I can get the bracket to push in under the holder tabs on the airbox, but the little latches are NO WHERE close to latching over the top of the airbox. I'm pushing really hard and they still dont get close enough. Am I doing something wrong, or should I just be pushing as hard as possible?
<- frustrated
Old Nov 6, 2002 | 04:41 PM
LowFuel's Avatar
LowFuel
Nevermind - tried it again and just had to stuff it down a bit before I tried to latch it - the top of the filter was getting in between the seams of the bracket and airbox.
Old Nov 6, 2002 | 04:49 PM
Vincey2kr1's Avatar
Vincey2kr1
Did you use the rubber peices(gaskets) that came with it, helps the filter stay in place.
Old Nov 6, 2002 | 05:59 PM
LowFuel's Avatar
LowFuel
Yep - still a slippery little bastard, but in the end it worked just fine.
Old Nov 6, 2002 | 07:06 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Exact same thing happened with mine. I just had to fiddle around with it to get it to go. I don't know that I noticed any big difference in performance to be honest with you. Sounds a little louder I suppose. Drive around a little and let us know what you think.
Old Nov 7, 2002 | 11:39 AM
Zoro's Avatar
Zoro
Default R U HIPAA compliant?
Doc, did you apply zaino to the filter, and inside of the air intake so the air would flow with less resistance.
Old Nov 7, 2002 | 06:21 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
No, but thanks for Zaino use number 4386. I'll put it right before Zaino-ing the antenna for incredible radio reception and just after applying Zaino to your CD's for crisp, clear sound quality!
Old Nov 28, 2003 | 12:53 PM
jckolnturn's Avatar
jckolnturn
Does anyone think the K&N filter is measurably better than stock?
Old Nov 28, 2003 | 01:02 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
K&N has changed part numbers and design. The one for the Z is the same partnumber but no longer requires the rubber gaskets.
Old Nov 28, 2003 | 03:47 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
imo, K&N is better than stock, since you can wash them and reuse them.. Make sure you buy the cleaning kit, also, don't oil it too much, extra oil may come off and get on the MAF sensor.
Old Nov 28, 2003 | 05:56 PM
MyZ4U2C's Avatar
MyZ4U2C
Theres been a lotta gripe over the oil and the MAF sensor. Just dont overoil it and a good thing would be to wait overnight until you install it....maybe put it in front of a fan all night that way any excess oil will have dried a bit.
Old Nov 29, 2003 | 01:20 AM
Jason@Performance
Performance Nissan
K&N Filter $39.95 Reusable for 1,000,000 miles.
K&N Recharger Kit $8.95
seagrasser
Oct 11, 2015 03:27 PM
350Shadow
Sep 22, 2015 08:30 AM
juang20
Intake
Sep 7, 2015 05:37 PM
