Topspeed Header Install Instructions
Old Jan 21, 2005 | 05:34 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Question Topspeed Header Install Instructions
Hi, is there a step by step for these headers or similar ones floating around on the forums? I did search so no flames please just useful information would be appreciated. Thanks,
Jarrett
Old Jan 21, 2005 | 06:59 PM
vics350's Avatar
vics350
This is not a step-by-step instruction but it should be helpful. Good luck with the install.
http://www.nezc.org/forum/viewtopic....f7b138effad683
Old Jan 21, 2005 | 07:58 PM
Redfoot's Avatar
Redfoot
use the instructions for the Crawford headers install at crawfordZcar.com. helped me out greatly. You just need to realize what you won't need to do for your particular brand. I wish I would have installed crawfords instead.
Old Jan 21, 2005 | 11:18 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Thanks guys..
and i thought stillen's put out pretty good numbers? or was it BS? did you not feel the affect? I have been very hesitant to install these headers after reading about alphawerks and crawfords and the numbers that they are putting down but I feel like if i dotn just get these on now I'll never do anything about it, not to mention I suck at re-selling stuff lol.
Old Jan 22, 2005 | 05:19 PM
Redfoot's Avatar
Redfoot
It was impossible for me to say that they did or did not increase my cars performace since I installed all of my mods at one time last spring. I have not done any dynos so I have no idea what my numbers were or are at this time. I do know that my car perfoms very well compared to other modded Zs out on the track. I was quite happy when I was able to out perform another modded Z that also had the 3.917 final drive and other mods B4 I had the new final drive installed. I thought for sure that he would have no problem pulling on me in the straights with the 3.9 but that was not the case.
I just wish that I had spent the few extra bucks and endured the more diffucult install for the Crawfords. CrawfordZcar seems to be the only company that is continually developing a Proven, COMPLETE NA engine performance package for our Zs.
Old Jan 22, 2005 | 10:46 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
ok, appreciate the response. ill see how it goes.
Old Jan 23, 2005 | 01:20 AM
Z BOY's Avatar
Z BOY
there's also a nismo header install guide on 350zmotoring.com, and i believe the topspeed install is more similar to nismo than crawfords, which require you to lift the engine a bit, from what i have read.
Old Jan 23, 2005 | 01:46 PM
350zbiturbo's Avatar
350zbiturbo
the guide i give you is dont do it, yourself and if you do buy a ratchet wrench dont blow me off on this one buy a 14mm ratchet rench itll save you alot of time believe me, my suggestion is drain the coolant and then have your friends disconnect on the coolant lines on the passenger side while you disconnect with your friend the coolant lines on the driver side so things go quicker and smoother, oh and alot of extensions buy more extensions, enough to be almost as long as your arms makes it ten times easier for tight spots
Old Jan 23, 2005 | 01:50 PM
Redfoot's Avatar
Redfoot
hence my statement about what won't apply to this particular install. Actually I used instructions compiled by a fellow member, peptidbond, which were very easy to follow, but the link in his post is no longer working.
Old Jan 23, 2005 | 06:28 PM
Z BOY's Avatar
Z BOY
can also contact topspeed for install instructions.
Old Jan 24, 2005 | 07:37 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Thanks for info guys, Dave from Smiley Garage ended up working me into his sched. and installed them for me over the weekend. I'll post a write up soon.
Jarrett
Old Nov 7, 2006 | 12:22 PM
Marshall2K's Avatar
Marshall2K
Are there any DYI 350z Headers installs with pictures out there?
Search didnt find much...
nanotech
Oct 2, 2015 05:02 AM
