Nismo ?
Old Jan 28, 2005 | 12:29 PM
LuksEaZy's Avatar
LuksEaZy
Default Nismo ? - Exhaust, headers, intake, and sway bars fitment on an 05 350Z?
Just a quick ? from you guys/gals will the Nismo exhaust headers intake, and sways fit on a 05 350z....
and does the Nismo exhaust come with all the gaskets to mount it up?
peace Jonathan
Old Jan 28, 2005 | 01:10 PM
DavesZ#3's Avatar
DavesZ#3
Jonathan,
The exhaust does come with gaskets and bolts & nuts if I remember correctly. I kept my stock exhaust and it came back with the old gaskets and hardware.
Dave
Old Jan 28, 2005 | 02:42 PM
mofoz's Avatar
mofoz
yep, the nismo exhaust comes with everything you need.
Old Jan 30, 2005 | 11:15 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
yes all nismo engine parts work on 05's...
i would not put nismo cams in an 05 until you can adjust the ECU...
all nismo parts come with everything you need. The full cat back exhaust comes with all gaskets and hardware needed. Sways come with harder rubber bushings...
Old Jan 30, 2005 | 02:39 PM
Conceyted's Avatar
Conceyted
Originally posted by AltaLad
Why wouldn't you want to install a set of Nismo cams in a new 2005 300Hp motor? Does it have to do with the new varible timing on the exhaust cam side?
read his post... 2005 ecu's have not been cracked yet therefore can not be reflashed.
Old Jan 30, 2005 | 05:39 PM
Jason@Performance
Performance Nissan
when I said 05 i mean non track models only...
that is until we figure out the lift / duration of the new cams in the 300hp motor... if they actually are changing that...
so far i havent seen new part numbers for any internals except rod bearings...
Old Feb 14, 2005 | 08:00 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved. Renamed title.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
