Ok guys...who has the Alpawerks headers...
Originally posted by 350zdanny
If you're going to pay for headers and an exhaust you might as well upgrade to high flow cats. You'll likely see modest gains with a header/exhaust and then tremendous gains when you install the cats because the stock units will still be choking off some of your exhaust flow whether you get the other two components or not.
It was even my understanding that some experts thought the cats were the most restrictive part of the exhaust.
The problem is noise. We constructed ours with this in mind. If you want to hear the test pipes go to...
There we have a video clip on the dyno. The best thing is that on the dyno you can really hear how the exhaust sounds (If it was outside you would have all kinds of background noise that will take away from the exhaust tone).
VIDEO AND SOUND CLIPS:
GO TO THIS ADDRESS AND SELECT "NISSAN 350Z (TEST PIPES)"
http://www.nexusindustry.com/alpha_frameset_dyno.htm
DYNO INFORMATION:
- DYNOJET DYNO (Speedlab Florida)
- SAE CORRECTED
- BACK TO BACK DYNO RUNS
- AVG. TEMP. 87 degrees
- ATMOSPHERE 30.58 in-HG
- COOLANT TEMP STANDARD APPROX. 200 degrees
TEST PIPE PICTURES
HEADER PICS AND DYNOS FOR ANYONE WHO MISSED OUT:
This pic is the first set that we dyno'd as a prototype. The final set is a little different to allow for ease of fitment.
I will do better then tell you how they sound...you can see the video clips...this is taken on a dyno through the entire rev range in an isolated space so there is no background noise from the street so you can here EXACTLY how the car sounds with the test pipes (car also has an HKS exhaust)...
I'd honestly prefer your expert opinion from hearing them in person. Sound clips, depending who recorded them from where and how, can be decieving. Is there the standard rasp at around 3k rpm?
Nabush
Aug 10, 2014 09:46 AM
