Steering wheel crooked after header install
Old Feb 16, 2005 | 04:49 PM
350Zenophile's Avatar
350Zenophile
Default Steering wheel crooked after header install
Anyone have this happen?
My mechanic tells me the steering knuckle can't be brought any closer or it'll rub the freshly installed headers. He recommends grinding it enough so that he can move it back which will re-center my steering wheel.
Is there an easier way of doing this?
Old Feb 16, 2005 | 07:47 PM
lovetoclown's Avatar
lovetoclown
What headers do you have? I installed my DC headers and had to center the steering wheel because it turned on me. But the knuckle is NOT even close enough to the header to rub.
Old Feb 16, 2005 | 07:52 PM
westpak's Avatar
westpak
SFZCC
If he disconnected the steering column to install the headers he might have reinstalled the column off by a few teeth from where it was before.
Old Feb 17, 2005 | 04:09 AM
Z CRUZN's Avatar
Z CRUZN
That's what happened after my Crawford header install - just remount the steering rack a few teeth over.
Old Feb 17, 2005 | 04:54 AM
350Zenophile
Thanks for the great suggestions and feedback.
They are TopSpeed headers.
I don't know if he disconnected the column to perform the install. I'll find out when I bring it back in. Is it possible to move the assembly over without disconnecting it? That was the impression I got from our conversation.
Old Feb 17, 2005 | 05:28 PM
alininger2001's Avatar
alininger2001
You have to disconnect the steering column to install headers, it doesn't matter which ones. There are two bolts that hold the knuckle on, you can loosen them up and realign your steering wheel. There should be some marks to line it up from the factory.
Old Feb 19, 2005 | 05:59 AM
bobd's Avatar
bobd
The knuckle turns with the the steering wheel. Why would it not rub when the wheel is turned? It just needs to be repositioned.
Old Feb 19, 2005 | 06:38 AM
2003z's Avatar
2003z
just disconnect the steering wheel inside the car and center it then reattach. be careful with the airbag though. I've had mine off several times when installing the steering wheel audio controls, and if you search for threads by gt3 you will find the instructions in his writeup on steering wheel controls.
Old Feb 19, 2005 | 06:46 AM
350Zenophile
You guys were right...I was able to check it out once he got it on the lift and that is all they did - move it back to the factory on-center mark.
I think the owner just threw out that theory thinking the column runs to the front of the engine bay like on all the mustangs he works on...brain fart or something.
Forgiven. I don't have any leaks or rubbing, and the steering wheel is straight again!
Thanks for your input.
HoBrahYouStink
Jun 24, 2016 10:58 PM
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
