??? for those with kinetix plenum
Old Mar 4, 2005 | 12:10 PM
tonester1011's Avatar
tonester1011
CF God
Default ??? for those with kinetix plenum
I installed my kinetix v4 plenum 2 days ago and since my car seems to be idling kinda funny, and when i rev the engine the rpms drop below normal then come back up and it sounds and feels like the car wants to stall. Im thinkin i may be running a little lean. Im thinkin that the comp. will reset itself eventually but i thought there was some other way to reset it. Any help appreciated...
Old Mar 4, 2005 | 01:03 PM
xephiron's Avatar
xephiron
Don't see why you can't just disconnect the negative terminal on the battery for like 5 minutes, that should reset the ECU...
Old Mar 4, 2005 | 04:40 PM
myz8a4re's Avatar
myz8a4re
funny idle could be vacuum related, especially since its appearent after the plenum swap.......i did my plenum right after the V4 came out...same idle before & after the swap.
-justin
Old Mar 5, 2005 | 06:17 AM
tonester1011
CF God
thanx guys
Old Mar 6, 2005 | 08:18 AM
slick099's Avatar
slick099
What do you mean vacume realted?
Old Mar 7, 2005 | 06:38 AM
GSoccer24's Avatar
GSoccer24
this won't reset the ecu on our cars, it is a flash memory much like the memory of a memory stick in a digital camera.
reset instructions can be found at www.technosquareinc.com
good luck!
Old Mar 7, 2005 | 06:48 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Make sure your seal is good. Run your finger around the bottom of the plenum while your car is idleing. Listen and feel for any small air leaks and tighten down the appropriate bolts
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
