Borla TD exhaust hitting suspension
Old Mar 12, 2005 | 10:22 PM
TunaRollZ's Avatar
TunaRollZ
Unhappy Borla TD exhaust hitting suspension
Anyone else with a Borla TD exhaust having issues with the passenger side piping hitting their rear right suspension arm? It happens only when the car bounces a bit after a hill or pot hole and the arm is pulled down by gravity. I've tried to rotate/redo all the piping in many different configurations and found that the most I can get is about .75 inch of clearance there.
Also the rubber hangers are getting stressed out...Anyone else having bad fitment issues?
Thanks in advance!
Jon
Old Mar 12, 2005 | 10:59 PM
ZIABLO's Avatar
ZIABLO
I am Batman
i had the same problem. when my tranny got replaced a few weeks ago, my guy fixed it for me by adjusting it. i think they caused the problem in the first place though, when they replaced my axles.
Old Mar 13, 2005 | 10:32 AM
TunaRollZ's Avatar
TunaRollZ
I see...so they were able to adjust yours out huh? I spent a good 2-3 hours readjusting the whole system in 10,000 configurations....It seems the most I could clear was almost an inch. I guess I'll try to release that hanger to gain another cm or so of clearance.
Anyone else having these problems? Are your hangers getting stressed out by the exhaust system?
Old Mar 13, 2005 | 12:52 PM
JoneZZZ's Avatar
JoneZZZ
I am looking to have a Borla TD installed soon.....is there any way of checking for poor fit immediately after the initial install?
Old Mar 13, 2005 | 02:48 PM
BENJ-AMG's Avatar
BENJ-AMG
Mine does the same thing. It was fine until after I got my cats. Now it bangs every time I hit a bump or pothole.
Old Mar 13, 2005 | 03:11 PM
GATORZ's Avatar
GATORZ
I have had the same issues after the Crawford cats. I also have adjusted the rear passenger side near the suspenion 10,000 times and it still vibrates or rattles when I rev or take off. The hangers do stretch to the max. I've read and tried everything on this site and now I just live with it. If anyone ever finds a good solution the beers are on me.
Dan
Old Mar 13, 2005 | 04:15 PM
ZIABLO's Avatar
ZIABLO
I am Batman
become good friends with the head foreman at your local nissan, then have him put it on the lift and go at it. that's what i did :-)
he was tired of driving my car and hearing the rattle (i bring it in a lot)
there was def no way i could have fixed it with just some of my hand tools and jackstands
Old Mar 13, 2005 | 07:34 PM
TunaRollZ's Avatar
TunaRollZ
Just keep an eye on the passenger side rear pipe right before the borla muffler can. It comes awfully close to the rear right suspension arm. Once the car is on the ground and the wheels are pushing the suspension back up, there will be a little less than an inch of space there.
TunaRollZ's Avatar
TunaRollZ
doh.
Not going to try and resolve the issue?
Old Mar 13, 2005 | 07:38 PM
TunaRollZ's Avatar
TunaRollZ
Dan
Ya...same here...I have helix test pipes and the borla TD...the rubber hangers are thoroughly pissed off and the right rear pipe just won't get anymore clearance.
For the time being, I removed the rubber hanger on that troublesome pipe. It helped bring the pipe down about 7mm :P I'm hoping it'll hit a bit less now.
I'm going to look for a bigger rubber hanger to use there. That way it won't pull up on the pipe and might actually act as a spacer so the pipe doesn't bounce upwards toward the suspension arm.
If all this fails, I'll probably just take her to a muffler shop and have that section cut out and a new mandrel bend welded in :P
damn it...
Old Mar 13, 2005 | 07:39 PM
TunaRollZ's Avatar
TunaRollZ
hehe...I might bring it to a buddy's shop and see if we can make any difference to that section on the lift.
I guess this is one reason the Borla TD was so economical.
Old Mar 14, 2005 | 09:39 AM
BENJ-AMG's Avatar
BENJ-AMG
Originally Posted by TunaRollZ
doh.
Yeah, I've got to have it fixed eventually. As soon as I can figure out how to get more than 24 hours out of a day.
Old Mar 14, 2005 | 09:56 AM
TunaRollZ's Avatar
TunaRollZ
lol true that.
So an update - Those 7cm that removing the hanger created seems to have worked so far. I'll continue running over small potholes lol.
Old Mar 14, 2005 | 12:56 PM
BENJ-AMG's Avatar
BENJ-AMG
Good! Hopefully that is the permanent solution for us. I'm gonna set up an appointment at Crawford next week and try your method out.
Old Mar 14, 2005 | 02:41 PM
hippie's Avatar
hippie
When I installed my Borla it looked really close so I tweaked and turned the pipes to get all the clearance I could. Sitting on the ground it only has 5/8in of clearance, but I've never heard it hit and there aren't any marks showing that it did.(I looked after reading this) Maybe it's the cats/test pipes or the potholes here just aren't as big...lol
hippie
Old Mar 14, 2005 | 02:58 PM
TunaRollZ's Avatar
TunaRollZ
Well, it's better now...but @ lunch today it did hit on the bigger dips and hills. I swear if I could get another half an inch, it'd clear perfectly....
If you look at the other side it has a good 1.5 inch clearance, and it never hits.
Old Mar 14, 2005 | 03:01 PM
TunaRollZ's Avatar
TunaRollZ
hippie
that's about the amount of clearance mine has there too. Mine hits only on the bigger potholes/dips in the road. Perhaps you're not hearing it...or maybe it's as you said...the test pipes are compromising the clearance aspects of the borla system.
Old Mar 25, 2005 | 07:50 PM
TunaRollZ's Avatar
TunaRollZ
Update:
Solved this today. Wasn't the suspension afterall...it was the stupid "M" brace that typically hits on borla exhausts lol.
Just pull down on the resonator pipes above the M brace and see if it can hit. If so, unbolt the clamps in that vicinity and put some wood blocks or a jack to hold the system up while you rotate the pipe for more clearance. Tighten the clamps and remove the blocks/jack and it should stay nice and far away from the stupid brace.
The other solution is to space the brace away from the body with spacers (talked about a lot on this board)...
Cheers!
Old Apr 2, 2005 | 12:27 PM
rocketrider's Avatar
rocketrider
My Borla was the first mod I did to my car. I also noticed the noise as soon as I put it on. Sounded like ****! When I took my car to the muffler shop to have them look at my test pipe "whisp" sound, he said he could fix it. He cut the hanger and then welded it back in place but at a slight angle. The extra weld made the hanger longer and the angle resolved any fitment issues I had before. I haven't heard it make a sound since.
Old Apr 6, 2005 | 01:40 PM
TunaRollZ's Avatar
TunaRollZ
did that resolve the hissing?
