Nismo cold air intake
the intake that is straight tube without disconnections is an older model of the nismo intake. I beleive it was a v1 or v2. The latest one (v3 i believe) looks just like the one you pictured. I was told by jason that the single tube (older model ones) had some trouble which is why nismo decided to switch back to the seperate tubing. In my opinion, the single tubing looks a lot better...
Originally Posted by blacktrack350
what kind of nismo intake is that? or what kind is this? cuz i want the one you have not this one
Originally Posted by amf813
Don't listen to this guy....He is just cheap. I have the AEM CAI and after seeing the Nismo CAI it was pretty obvious really that the Nismo's quality is much better than the AEM. You get what you pay for in my opinion.
You are a genius, Did you particpate in my poll i did a while back.
Guest
Posts: n/a
back to the cleaning of the nismo CAI
can you really go 15K with out cleaning (re-oiling it)?
i thought you had to to it alot more often. im on my 22d filter for the nismo CAI, my first one tore off!
ive got around 5K miles on it how much longer do you suggest i go
when will it start to cost you HP?
Guest
Posts: n/a
Originally Posted by King Tut
I have been told I have one of the rare Version 2 Nismo intakes. Apparantly the Version 1 and Version 3 both have 3 pipes whereas mine only has 2 pipes. I believe there were some small changes in design between the Version 1 and Version 3 as well. I ordered mine from Lee Auto Mall online. They might still have some Version 2s if anyone is interested. It comes with the bypass and a coupler for the lower pipe connection. I chose to use the coupler and have the bypass sitting on my counter top.
one if the differences between the V1 and V3 is the filter placement. the V1 is palces deeper down behind the wheel the V3 is at more of an angle where you can actually see a little of it. i have a V1 and i cant see my filet hardly at all. nismo thought the changed placement would allow it to breath better and get less dirty
Guest
Posts: n/a
bump for answer
Here are the words from K&N's site:
20. How do I know when to clean the filter?
The general rule of thumb is that the filter needs to be cleaned when the dirt build up gets as thick as the wire mesh. The usual interval is 30,000 - 50,000 miles depending on driving conditions. We recommend that you check your filter about once a year in normal usage.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
