Pop charger install ?
Old Apr 15, 2005 | 03:14 PM
bstfugtfomrfn's Avatar
bstfugtfomrfn
Default Pop charger install ?
All in all very easy. (but) there is always a "but"
But how in the hell do you mount those tiny little screws that attach the air duct to the heat shield. Yeah yeah.. i know you have to punch or drill holes.. thats fine.
Im wondering how do you get a screw driver in thier to tighten them when you have them lined up?
Any tips would be loved and admired.
~AJ
Old Apr 15, 2005 | 03:24 PM
hfm's Avatar
hfm
I used a small screw driver at an angle after drilling pilot holes.
Old Apr 15, 2005 | 03:26 PM
knight_white99's Avatar
knight_white99
I had a tough time with that too. I ended up just doing one hole. I have not had any problems. What looks easy and is supposed to take 20 minutes took me closer to two hours due to the darn little holes and the heat shield!
Old Apr 15, 2005 | 04:48 PM
baron's Avatar
baron
It was easy for me to drill the holes. I just took the screws, and screwed them into the plastic by hand.
Old Apr 15, 2005 | 05:36 PM
manofsteele2003's Avatar
manofsteele2003
I took a small Allen wrench and heated it up with a lighter and burned two small holes in the plastic for the screws to go through. Worked very well, alot easier than a drill IMO.
Old Apr 16, 2005 | 03:47 AM
bstfugtfomrfn
thanks for the tips fellas
Old Apr 16, 2005 | 04:40 PM
Low J.'s Avatar
Low J.
I used the tip of a soldering iron to poke the holes and it went through like butter....then just used a really short phillips head to screw them in.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
