Installed Motordyne 1/2" Plenum Spacer with OEM strut bar retained (pics included)
Old Apr 22, 2005 | 02:04 PM
  #41
Hattori Hanzo's Avatar
Hattori Hanzo
i'm not feelin this at all, it'll make your car look stupid with the hood proped up like that, looks like you forgot to close your hood or something.....this thread is gay.
Old Apr 22, 2005 | 02:13 PM
  #42
nismo33's Avatar
nismo33
BoNe SToCK BaSe
that's fine you are entitled to your opinoin. If you don't like it that's cool. now was the last part really neccesary. i suppose a bit of fellow Z courtesy is not too much to ask for. I think just saying that your not feelin it would be enough. oh well.
BTW welcome to the forum
Old Apr 22, 2005 | 02:34 PM
  #43
Hattori Hanzo
I was a little harsh on that last comment, I apologize for that man, I don't know you nor do I have any issues at all. I'm just a newbie having a bad day and I shouldn't have taken it out on you and your thread, my fault.
As for the idea, I'm still not with that because of the faulty weather us Chi people get, and I fear that the salt and snow would enter the engine bay. You're in socal so I'm sure you don't worry about weather much out there, but what about us midwesterners.
Old Apr 22, 2005 | 02:52 PM
  #44
nismo33's Avatar
nismo33
BoNe SToCK BaSe
no worries...in terms of plenum spacer then you can go with a 1/4" plenum with no clearance issue. i believe you can go as high as 3/8" plenum spacer with some adjusting. i think a few member were able to do this. with those plenum spacer should achieve a stealth look and retain the OEM look.
Virg
Old Apr 22, 2005 | 02:54 PM
  #45
Hattori Hanzo
will that hurt the flow of the air if I were to go with a 3/8" set up?
Old Apr 22, 2005 | 03:01 PM
  #46
nismo33's Avatar
nismo33
BoNe SToCK BaSe
from what i understand there's not much difference between the smallest plenum 1/4" to the middle sized plenum 3/8". i can't personally tell you performance or which one is better. but i know you can't go wrong, you will feel a difference in acceleration.
Old Apr 22, 2005 | 03:14 PM
  #47
Hattori Hanzo
hmmm, yea I knwo the bizz, I like the sound of that, I'm down for more accel. But the look is my concern though, even the smallest setting will show that crack won't it?
Old Apr 22, 2005 | 03:21 PM
  #48
nismo33's Avatar
nismo33
BoNe SToCK BaSe
if you mean the spacer will show not at all check this picture the spacer is the bright line between the upper and lower plenum. after time the color will match . hydrazine already had it the same texture as the plenums.
hope that helps
Old Apr 22, 2005 | 03:32 PM
  #49
Hattori Hanzo
interesting to say the least. good find. sorry for the comments earlier, I may consider this project down the road, right now I'm stocker then stock although I have the track model, nissan threw some nice stuff on it to begin with...don't know.
Old Apr 22, 2005 | 03:37 PM
  #50
nismo33's Avatar
nismo33
BoNe SToCK BaSe
it's cool all i can say choose your mods wisely cause it can be disheartning to spend a lot of money and not feel or see any gains. going N/A is so expensive and have minimal gains. F/I is the way to go, and maybe down the line i'm there.
Old Apr 22, 2005 | 03:40 PM
  #51
Hattori Hanzo
your sig says bone stock, but I highly doubt that man, what other mods you got? Maybe I'll follow your lead. Thing is I searched for exhausts and a whole buttload of products showed up, how do I know which one is best, there are sooooo many options out there.
Old Apr 22, 2005 | 03:50 PM
  #52
nismo33's Avatar
nismo33
BoNe SToCK BaSe
current set up:
greddy evoII exhaust
JWT intake
helix test pipes
1/2" plenum spacer
contemplating:
crank pulley
pipe dream:
twin turbo
Old Apr 22, 2005 | 04:55 PM
  #53
copba1t's Avatar
copba1t
This looks like a pretty cool idea for the track. I think it would be awesome if the brackets could somehow be designed to easily convert from normal closed position to the new slightly higher position, just with a simple adjustment of the brackets. Maybe some sort of a notched joint or similar...?
Old Apr 23, 2005 | 10:23 AM
  #54
MySunset350Z's Avatar
MySunset350Z
in the pic you posted, is that the 1/4 in spacer or the 1/2 with the hood spacer?
Old Apr 24, 2005 | 02:12 AM
  #55
Z350Lover's Avatar
Z350Lover
Sorry.. a bit off the topic here...
nismo33:
Why would you choose the spacer instead of the full replacement? I am currently looking into the plenum/spacer right now and don't really know which one should I go for... also heard that the spacer will probably cause the air leakage, is that so?!
cheers and thanks!
richie
Old Apr 24, 2005 | 05:32 AM
  #56
ZON's Avatar
ZON
Dang, just get the strut bar that will work! Your hood is getto now.
Old Apr 24, 2005 | 08:57 AM
  #57
350Zenophile's Avatar
350Zenophile
Now that would be sweet...some sort of ratcheting mechanism or something you could do with some basic hand tools.
I would think it'd get to be a pain in the **** to deal with latch alignment if you wanted to just put 'em on at track events and take 'em off afterwards. Also seems like a two man job. Do you have to remove the entire hood first or can you do one side at a time?
Old Apr 24, 2005 | 11:52 AM
  #58
owali1's Avatar
owali1
I think I am on the same page as z350lover, why not just get a whole new aftermarket plenum? Which one has the most gains?
Old Apr 24, 2005 | 10:29 PM
  #59
NourZ's Avatar
NourZ
you'll pay double the price and get the same gains.. I just paid for the 1/4" spacer $150 compared to $350 for a complete plenum. as far as the kenetix, it'll need to prove it self first and get cheaper second.
Old Apr 25, 2005 | 06:55 AM
  #60
TheBigShow's Avatar
TheBigShow
don't listen to these homos; your hood looks pretty cool, i think. i couldn't do that though (non-garage kept, daily driver).
