HELP ME greddy evo2 install
Old Apr 19, 2005 | 07:08 PM
adrenilan's Avatar
adrenilan
Default HELP ME greddy evo2 install
anyone know where i could get directions or have a write up. If you do please post a link or sned me an email adrenilan@comcast.net. I was so mad when i got the box and there was no directions. Thank you.
Old Apr 19, 2005 | 10:16 PM
CocaColaDrunkie's Avatar
CocaColaDrunkie
common sense.
Old Apr 19, 2005 | 10:32 PM
adrenilan's Avatar
adrenilan
Well considering you have to move some gas lines and reextend things i think a little more than common sense is involved. maybe you shoudl check more into things before you make dirogitory comments. Also you have to move a sensor taht is under the car. So id rather not have my car catch on fire thanks.
Old Apr 20, 2005 | 12:25 PM
baptist's Avatar
baptist
Do greddy not have it on the website?
Old Apr 20, 2005 | 03:09 PM
adrenilan's Avatar
adrenilan
unfourtunitly no i looked although they do have help for the turbo kit
Old Apr 22, 2005 | 10:33 AM
windydog's Avatar
windydog
There is a tread already in existance that states how to install the exhaust. In search, type greedy exhaust.
Best of luck
Old Apr 22, 2005 | 10:48 AM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
Best of luck
kenji from GReddy can help he does the tech support there very helpful. also the install is straught forward till you get to the mufflers. when you have the stock exhaust removed. also take off:
heat sheild above oem muffler
on the passenger side (it's a biotch) you have to remove the evap canister. to where the oem muffler was. it mounted using that black brace in the kit. i recommend to buy longer tubing, metal zip ties, and heat wrap for the tubing.
after you relocate the evap canister your home free.
hope that helps
sales@czp
Sep 23, 2019 03:30 PM
