Review of Motordyne Plenum Spacer
Old May 8, 2005 | 06:45 PM
deviant1's Avatar
deviant1
If installed correctly, you should not get the Check Engine Light. Check to make sure there's no leak and you reinstalled everything back properly.
Old May 8, 2005 | 08:05 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by GWAPITO69
i just installed my spacer but now the SERVICE ENGINE CHECK light came on... can someone help to take the light off.... nice plenum and easy to install..
By chance did you unplug the MAF sensor? This will do it if you had the ignition on.
You can reset the ECU by the pedal reset method or you can simply disconnect your negative battery terminal and let it sit for a couple hours. Reconnect it and the CEL should be gone.
If it still comes on, check to see if the OIL FILL grommet isn't stuck inbetween the plenum sealing surfaces. The spacer itself can't cause a CEL when installed properly.
Let me know how it goes.
Tony
Old May 8, 2005 | 08:08 PM
Hydrazine's Avatar
Hydrazine
Originally Posted by lgangi
Went to install my spacer yesterday and I had an incredibly hard time getting the gaskets to adhere to the plenum posts. ........
Anyone have same problem or know where I could find replacements? Is there an alternative method?
Did you remove the wax paper from the sticky gaskets? If you need more just give me a PM with your adress and I will send them out free of charge.
Tony
Old May 9, 2005 | 04:18 AM
lgangi's Avatar
lgangi
PM sent - thanks!! Great customer service is so hard to find these days.
Len
Old May 9, 2005 | 09:10 AM
GWAPITO69's Avatar
GWAPITO69
Tony
Thank's for the help and spacer. I disconnect the negative battery for a few hours and now it's running great. no more light
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
