JWT Installation question
Old May 18, 2005 | 06:17 PM
slowxturtle's Avatar
slowxturtle
Default JWT Installation question
Do you need to screw the heatshield to the air passage with the two screws? I ask because the part of the heatshield that is suppose to attach to the plastic air duct is angled such a way that It doesn't sit flush wtih the passage peice. I have to bend it about 3/4" and that sucker is stiff. I just left the screws off for now. I did put two bottom bolts that are tightented onto the rail which holds the heat shield in place.
Old May 19, 2005 | 06:56 AM
Low J.'s Avatar
Low J.
yeah, I used the 2 screws to mount to the air duct as well. I used a soldering iron to start the holes and a really stubby screwdriver to screw them in from inside the duct.
Old May 19, 2005 | 09:31 AM
GWAPITO69's Avatar
GWAPITO69
when i installed mine. i did not screw it i just used double sided tape on it.
Old May 19, 2005 | 12:49 PM
slowxturtle
Interesting, 1 problem is having to bend the shield to line up with the plastic duct. I'm thinking only mine is oddly shaped.
Workshop12
Mar 23, 2020 01:45 PM
NFAC
Sep 26, 2015 10:11 PM
Suffolk350z
Sep 13, 2015 02:43 PM
juang20
Intake
Sep 7, 2015 05:37 PM
