Nismo Exhaust Rattle?
It seems as if my car rattles when i turn it off... doesnt souns too good.
the is coming from the bottom of the car =/
anyone else having hte same problem?
I may be having something similar to you actually. Hey I see your in Arcadia if you have free time we can put both Z's together to see if its the same thing.
I do hear soemhting like rattle as the car turns off.
pm me the details of when u'll be good to do this... ill be good anytime after thursday (last final)
Originally Posted by ZU L8R
Check and see if it's rubbing your rear crossmember. There's been a couple threads on it. Do a search you'll just put a couple spacers in it.
This rattle might be the flywheel/gears rotating back and fourth as the engine is shutting down. Try pressing the clutch in when shutting off the engine to see if that stops it.
