Question: Intake Manifold...Any good for boosted Z?
In the ever greedy search for hp, I've seen the intake manifolds for the Z. Do these work a. well b. well with forced induction? Just looking for someone with experience...dont want to blow useless cash. Also, what kinds are best (if any) and what kind of gains did you experience?
I have had good luck with both the Crawford and now the new Kinetix SSV.
If you just want the power, I'd go crawford. If you want the power (similar to the Crawford v5 or Kinetix v4) AND some serious bling factor, go with the SSV. I know some have had success with the Kinetix V4, but I'd still go Crawford over that... still not comfortable with the idea of a plastic intake plenum.
I think Andy and Nis hit it on the head. Most of the plenums will provide similar gains, provided that your car is retuned carefully and thoroughly with the new plenum. In to the power gains, you should see better air distribution between cylinders, and a higher volume plenum is especially helpful with F/I applications.
Most likely, the APS Plenum will acheive similar result to the Crawford, but at a lower pricepoint.
