Random Tech CATS Blown out???? HELP!!!!!
Old Jul 11, 2005 | 08:04 AM
Gary King's Avatar
Gary King
Originally Posted by SixRB6
Hey Gary,
It sounds really great..I like it even more not at all raspy...makes you want to drive it harder!! I see your in ny......Do you know where I can get tires?? I need Nitto 555's 235 or 245 35 19 fronts....and 275/30/19 rears...
You can buy my tires. I have that exact tire combo (245/35/19 front, 275/30/19 rear) on my car which I have put about 3000 miles on. They look pretty much brand new. I want to try the new Toyo's and have been thinking about selling them. I'm outside of Rochester if that's not to far you could check them out or I could send you pictures.
Old Jul 11, 2005 | 08:27 AM
SixRB6's Avatar
SixRB6
How much do you want for them and you can email me pics to SixRB6@aol.com.
Give me a tread view side view and whatever else you think will be helpful
Old Jul 11, 2005 | 09:07 AM
Gary King's Avatar
Gary King
Just sent you an email with pics.
Old Jul 11, 2005 | 12:38 PM
pimp1911's Avatar
pimp1911
SixRb6 congrats and you saved money.
Old Jul 11, 2005 | 12:48 PM
booger's Avatar
booger
No cats flow as good as the RT's ....bad side is they do not work in our car with out collapsing...The Crawfords I have now sound good but dont flow nearly as good .
Old Apr 24, 2006 | 08:48 AM
kzanard's Avatar
kzanard
Can any who have had the RT Cats fail describe the difference in exhaust sound? I am trying to seeif this is my issue now.
Thanks.
~ KZ
Old Apr 24, 2006 | 08:53 AM
tonio's Avatar
tonio
The exhaust sounds very mumbled and there is a noticeable difference in a loss of power.. its not a good thing because it causes a lot of backpressure that could damage your engine.
Old Apr 24, 2006 | 08:56 AM
kzanard's Avatar
kzanard
Thanks Tonio. I have done some more searching and found other threads. it sounds like what I am experiencing may be the R/T's collapsing.
I have a set of Crawfords sitting at home I bought last year & never put on so I am going to try and find a shop to switch them out this week to see if that does the trick.
Old Apr 24, 2006 | 11:46 AM
booger's Avatar
booger
You will more than likely need to re-tune your car after you put on the Crawford cats . Your gonna gain some boost because they are more restrictive . I gained 1.5psi when I switched
Old Apr 24, 2006 | 12:03 PM
kzanard's Avatar
kzanard
Thanks Booger, that's what I thought anyway. I plan a tune after any intake or exhaust mod. I had Crawfords on a long time ago and I remembered that they were more restrictive. I think they were a little quieter than the R/T's too which is a plus. I just hope it is the cats that are causing my current woes and not something else. I will update after I have them changed out.
Old Apr 24, 2006 | 12:08 PM
booger's Avatar
booger
Mine collapsed when I was at the track .Thought I had broke something inside the motor . You will be able to tell once you get them off . The metal inside pushes out in the middle and the reast collapses down and plugs up the exhaust ....good luck
Old Apr 24, 2006 | 12:56 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Thanks.
~ KZ
Mine failed after 6 days and it felt like a 4 banger. then went into limp mode
Old Apr 25, 2006 | 08:05 AM
kzanard's Avatar
kzanard
Just got a call from the shop. The passenger side cat is collapsed. Now the problem is they are telling me there is not enough room on the Crawfords to weld a bung for the wideband before the cat! I am pretty sure my old Crawfods had the bung there.
Those of you with Crawfords, can you verify if the wideband was successfully welded before the cat?
Old Apr 25, 2006 | 02:56 PM
kzanard's Avatar
kzanard
It was the cats - whew! The Crawfords are in and sound is back to normal. Here is the culprit...
AbrasiveRaysive
Sep 20, 2021 02:29 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Li1ag
Sep 28, 2015 02:07 PM
