Will exhaust air leak give you rough idle??!!
Old Jul 22, 2005 | 01:12 PM
Bahraini350Z's Avatar
Bahraini350Z
Default Will exhaust air leak give you rough idle??!!
Got headers, TP, Y-pipe and catback! Can hear an air leak and feeling this CAMs-style roughness!! The RPM drops and the car nearly stalls!!
feedback is appreciated
Old Jul 22, 2005 | 03:09 PM
QuantumZ's Avatar
QuantumZ
YES. Leaking headers will let air get in before the front O2 sensors (which are widebands, BTW) and make the car read richer or leaner than actual. This could yield funky closed loop A/F corrections for one side or the other and give you the situation you describe. It isn't to say that the car is simply adapting to the new complete exhaust, but I doubt it. An OBD2 scanner will tell you if the closed loop correction for one side or the other is way off, etc.
Mark
Old Jul 22, 2005 | 03:12 PM
teh215's Avatar
teh215
03 Models do not have WB O2 sensors...
Old Jul 22, 2005 | 09:04 PM
QuantumZ's Avatar
QuantumZ
My bad. I was speaking from my own Z which I've been around quite a bit. Didn't know that. I have a bastard 04.5 so it's a little different than most. Regardless, the same issues will result from leaking headers.
-Mark
Old Jul 22, 2005 | 11:39 PM
hndumafia's Avatar
hndumafia
wait...then what are the sensors that go into the cats? those aren't wb 02 sensors???
Old Jul 23, 2005 | 05:27 AM
Bahraini350Z
thanks
Old Jul 23, 2005 | 05:30 AM
booger's Avatar
booger
could also be a vacuum leak causing the ruff idle
Old Jul 24, 2005 | 05:42 AM
Road Warrior's Avatar
Road Warrior
i'd say vacuum leak more so than exhaust leak.....just make sure everything is tight
can you hear the exhaust leak?
Old Jul 24, 2005 | 06:36 AM
Bahraini350Z
I can hear the exhaust leak and smell fuel somtimes!
Old Jul 24, 2005 | 06:49 AM
Road Warrior
sensors on the headers???
Old Jul 24, 2005 | 04:50 PM
350zWarz's Avatar
350zWarz
yea there are sensors on the headers, i put mine in so i know that at least the 03 ones do
Old Jul 27, 2005 | 03:53 AM
Bahraini350Z
Problem found!
A CRACKED plenum!!!!!
Old Aug 4, 2005 | 08:04 PM
hndumafia's Avatar
hndumafia
what kind of plenum was it??
Old Aug 5, 2005 | 08:38 AM
vfr350's Avatar
vfr350
My old nissan 200sx was so vacuum sensitive, pulling the oil cap off while it was running would cause a rough idle and make it almost die.
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
