Those with aftermarket intake plenums...
these are my major pro's and con's...
Kinteix:
pro's = Zero Modification / life time warranty (as long as the company exists at least)
con's = PLASTIC???? (but apperantly it's better cause it's lighter and doesn't heat up)
Crawford:
pro's = Tested and "approved" by many people
con's = New Strutbar + Mod Engine cover.
The gains seem to be almost identical... can they both handle boost as well? Also, is Kintexi's material (plastic) an actual CON vs Crawford's cast iron?
linke to kinetix:
http://www.kinetixracing.com/index.a...&ProdID=9&HS=1
linke to crawford:
http://www.crawfordz.com/plenum.htm
Kinteix:
Crawford:
linke to kinetix:
linke to crawford:
Originally Posted by gatti-man
didnt the kinetix have a problem with melting or is that an old wives tale? Since i live in texas that stuff scares me lol
Now the reason to get either, is with the stock plenum there is a design flaw with regards to the air flow to the cylinders. To clear the "Z" hood, and still allow for the STB, Nissan designed the plenum with an angle. In doing this, the rear cylinders receive more air than the front cylinders. Crawford noticed this, and was the first out with their solution. Other's have since followed. IMO, the Crawford solution was, and is still the best one out there.
And yes, I had one of the first Crawfords, and I now have a V4. The latest is the V5, and is all cast, rather than a modified stock plenum like the one I have.
Lou
don't even consider a kinetix. search the forums and look at all the issues people have with them....cracking, melting, rubbing on the stock bar, and the list goes on. Yes, you may need to get a new strut bar and take the engine cover off with a crawford, but much better than having your plenum warp or crack
) Their customer service is second to none. Keeping the stock engine strut bar, and even the engine cover (with the back two screws loose) is a plus. Matched with some Kinetix high flow cats, your Z will sound mean....
Originally Posted by ZBoater
Those are really old posts. Yes, earlier versions had problems, but ever since their V4 came out they have been rock sold (platic solid?
Read all the posts and make up your mind. My opinion is to stay away from anything kinetix. Plenum is plastic...enough said. Cats have bad welds, crack and burn out....enough said
I say F*ck it, get a narrowband A/F gauge when you get your Kinetix plenum. That way you will two sh!tty 'mods' on your car... oh wait, you recommended the same kinetix cats that have bad welds, crack and burn out. That would make it atleast 3.
I've had the plenum and cats for almost a year now. They work absolutely fine. I am having a bit of a vibration between the heat shield and one of the cats, nothing that a well placed hammer can't fix in 20 seconds.
You, on the other hand, seem to read some posts, you parrot what they say even if they are 2 years old, and take them as gospel. If I were you, I would THINK before you post. Your posts will come out much better.
At least you are thinking a bit more. Now, stop reading old posts and repeating mindlessly, and you will have made another huge leap forward.
I'm glad you went back and cleaned up your previous post. You did it quick too so it wouldn't show an edit. Too bad I hit reply right after you posted the first time.
I will repost if it makes you feel better - this was my orginal post for all to view, no shame here: (don't know if I will get the words exactly right, but it went something like this)
"Go ahead and get the kinetix plenum. While you're at it, get a narrowband A/F gauge. That way you will have two sh!tty 'mods' on your car...oh, kinetix cats were recomend as well, that would make it 3."
The whole reason I edited the post was because I thought it would be more usefull to the originator of the thread why I wouldn't consider kinetix.
I don't want to totally bad mouth Kinetix, they do have good customer service and their new plenum sure looks pretty
Please advise what posts I am repeating mindlessly
I have also read that a plastic plenum is NOT recommended if you go FI. This makes sense to me, and I wouldn't recommend it either. Their new SSV though..... sweeeeeeeeeeeeeeeeeeeeeet.
Ok, advising (is that a word?)
I've had the Kinetix V4 (first and only plenum from them I've had) for almost a year, and I have not experienced ANY of these issues. I too read the posts about their V1-V3 and the issues with cracking, etc. But they have had several releases and their V4 works fine. No cracking, no melting, no rubbing the stock bar.
Oh, Zboater, please advise again on a post that I am repeating mindlessly as you have yet to do so, despite the fact that you think you just did. Maybe you can tell me
What's a cam? What's a pulley? What's wrong with the stock ones that aftermarket ones make more power?
Maybe not the best person to take advise from
...Maybe not the best person to take advise from
TROLL!
And, just in case you don't know what a troll is, here is some reading material for you
http://members.aol.com/intwg/trolls.htm
And now, for a magic disappearing act, the IGNORE ZIVMAN button!!!!
Click on Zivman, View Public Profile, and click on Ignore Zivman. VOILA!
Ok, so you dig up a post from 9/28/04 where I ask a question and you are holding that against me? So I didn't know, and I asked. Someone answered, and I learned. That is what people do when they come to these boards, unlike you, who apparently comes here to
TROLL!
TROLL!
