Popcharger Install (PLz HELP!!!!)
Old Aug 10, 2005 | 10:20 AM
Tay350z's Avatar
Tay350z
Default Popcharger Install (PLz HELP!!!!)
Hey guys I was wondering if I can talk to someone about installing this jwt popcharger. I am having trouble getting the box off. There's a bottom screw that I just can't get to. Also does the MAF sensor just pop out or do you have to unscrew those small little gold screws ? Thanks a lot. If you have AIM this would be easier thanks!
Old Aug 10, 2005 | 12:34 PM
ZlleH's Avatar
ZlleH
There is no bottom screw. the Filter Box is just secured down by a wedge kind of thingy. just pull hard and the air box will come off. They don't warn you about that in the instruction.
And the MAF sensor can be taken out without having to unscrew the gold screw. But you don't have to take the MAF sensor off. just the 2 -3 inch pipe section that the MAF sensor is hooked to should be taked apart from the long pipe.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
