Just installed popcharger; car cut off on highway...
Had to tow my car to the dealer today. The dealer stated that code it is throwing out has something to do with the Throttle body. I think this is bull and it has to be a transmission issue because the TCS OFF and SLIP light both came on at the same time when my car went into fail-safe mode.
Not too great of an experience on my Z so far with only 600 miles and 2 issues already.
Update: Got my car back from the dealer and they said that the intake install caused the problem. Here is what you guys should do if you are considering installing an intake system.
Either dis-connect the battery before the install or leave the O2 sensor plugged during the install. Most aftermarket systems still use the same 02 pipe so just leaved it plugged in to the housing and work around it.
Thanks for the update.
When I did mine, I unplugged my battery, installed the intake, and then went to bed. The next morning I plugged the battery back in and started driving. I've had no problems other than 1 sleepless night waiting to try out the intake.
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
