Need Information on the JIC Twin SUS Exhaust
I have never seen this exhaust till today, Does anyone have pics, sound clips, or dyno information on it? I understand it needs a Y-pipe with it, Also with the 60mm piping would it be good for an NA set up? TIA for any help!
HERE is a link to the exhaust.
from a y-pipe to a single pipe, then back into a y-pipe.. I'd go for true dual instead or Nismo style, but that's just me.
plus, if it's 60mm before it splits into the two-sides, that's smaller than stock. 60mm is about ~2.36 inches, whereas stock is 2.75 AFAIK
very sorry if I wasn't productive
I would search about the stock y pipe but if I remember right, it might be 2.25" into 2.75" where it merges into the B pipe. The B pipe and the rest of the exhaust is 2.75", again if I remember correctly.
Most aftermarket single pipe exhuasts like the Nismo are 2.5" y pipe merging into a 3", hence the gains.
You could also consider a custom setup if you don't like the current true dual exhausts like the Stillen. The best for a normally aspirated setup would be a 2.5" catback piping. You can choose what kind of mufflers you want to go with. Search on these forums, there is tons of people that have used different mufflers, you could even do dual HKS carbon-ti mufflers... but I think those come in 3" piping only, for NA, I'd keep it 2.5" on each side.
Thanks man! I never really put thought into going custom, is that a pretty expensive route? I would like to stay under a grand for the setup, and can normal muffler shops do a custom setup or would I have to go to a performance shop? Thanks again
