Helix Dyno Proven Prototype Exhaust (dyno and pic in side)!!!
Old May 19, 2006 | 11:13 AM
  #121
aznmojo's Avatar
aznmojo
trust me the exhaust does not hang low at ALL, not as low as some of the true duals i have seen.
Old May 19, 2006 | 01:55 PM
  #122
LODOSS's Avatar
LODOSS
well then i guess im gonna pickup the Helix . 3 inch with my tn 3 inch.. should give me a nice little bump.. i hope
Old May 20, 2006 | 07:05 PM
  #123
mistermojorizin's Avatar
mistermojorizin
Originally Posted by Cronic
Numbers aren't important. They mean nothing really. The gain is what we are after. If the car made 100whp on that dyno and gained 10whp, then the same car was brought to a different dyno and it made 300whp, and still gained 10whp would the car be any faster since it dynoed higher?
of course ther's a difference. the first dyno showed a gain of 10% and the second showed a gain of 3%. you think the gain is the same?
another way to look at it, is to convert it back to flywheel hp. say you have a car rated at 300flywheel hp. you put it on a dyno and it reads 100whp. Add a mod, and you get 110hp. The mod added 30flywheel hp. That's like the difference b/w a Z and an m3. Now, say you are testing mod #2 on dyno #2 on the same car. Dyno #2 says the car makes 300hp (a 1 to 1 whp to flywheel ratio - its unrealistic, but it makes the math easier). Now you add mod #2, and it reads 310hp. Well that's only 10 flywheel hp too then, not much of a difference.
the point is - 10hp on a dyno that shows really low numbers, like say a mustang dyno, is a lot better gain than 10hp on a dyno that shows really high numbers, like say a dynapack. You can't just use subtraction and say the gains are the same, because it takes a much bigger increase in real power to show the same increase on a lower reading dyno.
Old May 20, 2006 | 08:38 PM
  #124
jondimellow's Avatar
jondimellow
hey thats my car!
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
