Installation of test pipes?
Okay guys, i just installed the popcharhger last night in about an hour with my friend. I have the intense motorsports race pipes in my garage waiting for installation. First off i highly reccomend the popcharger. IT sounds so nice and around 5 thousand rpms the engine screams so loud and I love it. Anyway i was curious about the installation of the testpipes. My friends and I are goin to put it on in his garage because he has some airtools and stuff, but i was just curious on how hard it is to put the test pipes on and how long it would prob take. Iv been told that on the 03 Z the cel will not go on. Is this true? thanks
test pipes are pretty straightforward to install. I'd like to give you a huge warning about the driver's side o2 sensor though, it feels like its was welded on there. My friend and I projected that it would take us no longer than 2-3 hours but we ended up spending 9 hours, most of which was because of the o2 sensor. You probebly will get a CEL but theres a number of ways to fix that
just did mine this weekend. shouldnt take more than 3 hrs.
your going to have to buy new bolts(size of 10mmx20mm with 17mm head worked well for me, all ss). a total of 10(4 per pipe and 1 per pipe for the brace(not all pipes use the brace). you get to reuse two of the studs/nuts simply because you cant remove them.
the passengar side bolts are alot tighter than the driver side. shouldnt be a problem for the air tools tho. getting the header bolts from the topside was easy, but youll need about 36 inches of extentions.
dont forget about washers, lock washers and maybe locktight.
i dont know how others removed their o2 sensors, but i had to take the hammer to the outer case to get my crescent wrench on it.(22 mm nuts)
good luck with it.
good luck with it.
Originally Posted by BlueDragonZ
Okay that's scary. How has everyone else remove the O2 sensor with hammering it down and taking 9 hours? Also I was thinking of getting the APS TP's any suggesttions/comments?
Tell us how the APS's sound, maybe a sound clip if you can. i want to get those but i was told you should not think about them unless your thinking of FI
You can go to ANY autoparts store and buy an O2 sensor socket, which has a cut out on it so the wire fits through. Then it is a matter of just unbolting it like anything else. took me about 30 seconds.
Took about an hour to switch out the cats with the test pipes. I used a lift and hand tools.
or you can go to Autozone and borrow one of there O2 sensor socket.
