Plenum or Plenum Spacer?
Old Nov 16, 2005 | 03:55 PM
RedBird's Avatar
RedBird
Default Plenum or Plenum Spacer?
Is there a difference in power gains?
Old Nov 16, 2005 | 05:05 PM
Jtrain's Avatar
Jtrain
Good question- I found a plenum for the same price as a spacer, so I grabbed the plenum... WotS is that plenum gives a little sound.
Old Nov 17, 2005 | 06:46 AM
DaveO's Avatar
DaveO
You might want to check out...
Old Nov 17, 2005 | 10:02 AM
GMADD's Avatar
GMADD
Is it out yet?
Haven't received mine yet
Old Nov 17, 2005 | 10:23 AM
southern_info's Avatar
southern_info
Do ya'll think you could get a little bit more gain with the spacer and plenum being used together than w/ just 1 of them?
Old Nov 17, 2005 | 10:24 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
i would go with spacer. I had them installed. Cheaper and give out pretty much the same gain.
Old Nov 17, 2005 | 10:54 AM
injendsm's Avatar
injendsm
can you get those in a bookstore or do you need to subscribe online? i checked one bookstore but didnt see it.
Old Nov 17, 2005 | 11:17 AM
sisco534's Avatar
sisco534
Sweet magazine.....sell a lot of those! Where at?
Old Nov 17, 2005 | 12:42 PM
RNL323's Avatar
RNL323
Mod My Ride
+1
I don't think Sport Z is widely distributed. I have seen it at a couple Barnes and Nobles. The 1st issue I ever bought was at a random liquor store.
Old Nov 17, 2005 | 01:34 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
if you want to save weight, go with aftermarket plenum.. if not, go with spacer..
Old Nov 17, 2005 | 05:46 PM
injendsm's Avatar
injendsm
Originally Posted by RNL323
+1
i went to a barnes and noble tonight but didnt see it oh well, ill check a couple more and if i cant find it anywhere, ill just end up subscribing.
Old Nov 17, 2005 | 07:16 PM
myehrick09's Avatar
myehrick09
I thought the spacer weights lighter comparing to an aftermarket spacer?
Old Nov 18, 2005 | 06:24 AM
NA&CH's Avatar
NA&CH
I believe he is calling the stock plenum a beast. I am going to read that shootout and make my decision.
Old Nov 20, 2005 | 07:37 PM
Jtrain's Avatar
Jtrain
Well the cheaper plenums, I THINK, are just to fix a small air flow problem with the vq35 (at least with the g35's)
So you may see a little gain, but I doubt it would be much more than a 200$ overkill.
Old Nov 20, 2005 | 09:03 PM
No one has mentioned one potential advantage of the spacer IF the spacer has a thermal gasket (or 2). And that's heat sink or thermal isolation. Hot air rises, and the plenum gets hot. A thermal gasket may help keep the OEM plenum cool.
Old Nov 20, 2005 | 09:06 PM
What about two spacers and an aftermarket plenum? I forgot: you'll need a new hood too.
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
