I recieved the new MREV mod in the mail!!
Originally Posted by Diesel350
Yes I will be doing those tests also. Tony, what's the ease of install of this mod for a novice?
I had never used a torque wrench, let alone seen one, until this mod. I was able to finish the MREV install by myself in about 2-1/2 hours. Thinking back, now . . . I could have saved myself a bit of time by pre assembling the CCV with some RTV Silicone , disconnecting the intake tube, disconnecting and tucking away my GroundingGear wires the night before.
Good luck and have fun with your install.
Originally Posted by Jason@Performance
REV UP motors have been safley run with no modification to the internals up to 7800 RPM and made power till just below then, with a new cam even more HP will be made up to there... So, if you run up to 7800 RPM on the REV-UP motor you will have more constant peak HP at high RPM's which will be sweet on the track... Daily Driving / Free Way driving will not really see this power...
Originally Posted by GAaaAR
What if you used the modified lower plenum with a 1/2" spacer, would that be better than using a 5/16 spacer?? Would there be even more gains in the topend????
Would this be helpful if I put it on my 04 287 motor? Right now I have the Rev-up lower plenum and it provides gains on the top end but removes bottom end tq. Which would be a better setup?
i have a 287 03' motor, and i already have a spacer, so if i added the modified lower plenum would i see more HP at topend? also, do you sell just the modified lower plenums?
If you don't have any other kind of plenum mod, then yes. It will provide good gains and be 100% stealth.
In fact, I may be able to modify your current collector by using a core swap to cut costs.
Here is what I have on the website so far.
Still needs work but the basic structure is finished. Not much longer.
http://www.designbyvani.com/tony/350Z.htm
Tony
Originally Posted by Hydrazine
Yes, you will see more power at the topend but not much more. Clearance above runners 1&2 becomes more of an issue as the RPM increases hence the modified collector will provide more of an advantage to the REVUP engine.
Tony
Tony
Yes, but probably not in the comparative way you are looking for. But you also don't need it to know the difference is there. Spacer heigth Vs HP has already been mapped on the 287 engine.
See the comparative plots in the tech section of my web page. 1/4" Vs 1/2". The 1/4" spacer produces very good gains in the high end even though it is only a 1/4" lift. There is only a 1.6 HP difference between the 1/4" and the 1/2" @ 6500 RPM. And if the delta is 1.6 HP at 6500 RPM the spread will only increase at 7K RPM.
I won't say how much the collectors are machined but the plot is a good example of Bernoulli's equation in effect.
subscribing. Definitely great bang for the buck with this setup. Motordyne is an exceptional company, and Tony has done his homework and knows what he's doing, and is providing an exceptional product line! Stay tuned to our site!
When used with a spacer yes. When a spacer isn't used it will make about 5-7 HP.
More flow clearance is better, but recent MREV test data suggests more internal volume isn't isn't necessarily better. The 5/16" produced more than either the 1/2" spacer or none at all. So there are various different optimum points and compromises at work.
Modifying the collector is one way to approach the best of both.
See... I told you all to stay tuned to our site!
http://www.partshippers.com/index.ph...ain_page=index
We are proudly selling the complete line of Motordyne Plenum mods including this MREV featured here. We will be posting a Vendor Classified soon!
Originally Posted by rolling
so,
to do this mod complete what is total gain?
do you machine the parts like an exchange/ core program?
or how?
what is total cost?
thanks!!
or how?
what is total cost?
thanks!!
The excahange/core program will only work with 287 engines. Otherwise you need a MREV.
also does that mean if the 287 motor had the 300 plenem setup its hp would increase and tQ decrease?
