results of basic power adders to the newer 300hp motor....
Old Nov 23, 2005 | 01:42 PM
Speedracer's Avatar
Speedracer
Default results of basic power adders to the newer 300hp motor....
I had heard someone mention that the newer 300hp motor would respond much better to the basic bolt-on type mods due to the improved variable valve configuration. Any confirmation of this?
Old Nov 23, 2005 | 09:46 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The MREV works really good. Here are two of the most recent independant dynos. All show a massive increase in area under the curve, along with a wider power band.
Old Nov 27, 2005 | 04:19 PM
InItIaLD's Avatar
InItIaLD
looks extremely similar to my graph on a dynojet, on my 04 touring 6mt (with popcharger as my only "mod") and i dynoed 243rwhp and 237rwtq
Old Nov 27, 2005 | 06:54 PM
Hydrazine's Avatar
Hydrazine
The above MREV dynos are from modified 04 lower collectors with a 5/16" spacer on a REVUP engine so the curve shape on theirs and yours should be similar. With the exception being in the effect of variable exhaust cam timing and a higher redline limit.
EDIT: Oh yeah... I should add that MREV is not a mod to increase the peak HP. Its a mod for increased area under the curve.
Old Nov 28, 2005 | 08:13 AM
partshipperdave's Avatar
partshipperdave
right. it's a true torque mod - something you'll notice more than added HP - especially on street cars where you're primarily working in the mid rpm range.
HP sells cars, torque wins races.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
