Nismo exhaust Questions
Old Dec 19, 2005 | 04:25 PM
zipgun's Avatar
zipgun
Default Nismo exhaust Questions
Tried searching and probably a stupid question but what the heck,
Does it need a muffler replacement etc..after a certain amount of time? And if so what part is it? What kind of life span does an exhaust system like this have?
And does black soot on tail pipes and back of the Z, normal? and would getting headers etc.. make more soot?
Old Dec 19, 2005 | 06:14 PM
A stainless steel exhaust should last the life of the car. The problem with OEM exhaust is corrosion. Corrosion eats holes in the exhaust, and parts must be replaced. Corrosion is more predominate in areas where it rains often and humidity is high. In Arizona for example, the OEM exhaust might last 10 years.
All exhaust pipes get dirty.
The catalytic converter is designed to limit hazardous emissions: not dirt or smoke.
Old Dec 19, 2005 | 07:28 PM
zipgun's Avatar
zipgun
Thanks davidv, for the info.
Old Dec 19, 2005 | 10:21 PM
InZomniac's Avatar
InZomniac
I have the ******* soot too. Mechanic told me tha car was just running rich because it was winter. Riiiiight, sounds like bs to me but we'll see what a compression test says when I change the plugs.
Old Dec 19, 2005 | 11:08 PM
808_FairladyZ's Avatar
808_FairladyZ
I have intake, headers, and a Nismo Exhaust System and it looks just as good now as it did a year ago( actully, the exhaust changed color closer to the engine). I just changed my oil on Sunday, so i checked it out. My mesh bends are fraying though from bottoming out( it sits lower then the factory piece). My exhaust also gets a little black after about two weeks but i think it's normal. My factory exhaust used to do the same thing. It washes of easily, so it doesn't bother me.
Old Dec 20, 2005 | 05:39 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
It is quite possible that the fiberglass wool packing the muffler may be breaking apart. I have never seen this with a Nismo exhaust, but it's possible with any muffler in general. The soot that you are talking about, does it look like there are tiny fibers in it? or just black soot? Black soot is reletively normal for most exhausts especially on our cars, just the contaminants or carbon coming out of the exhaust gases... Even stock exhausts do it to a point. I don't think it's anything to be alarmed about tho.
Old Dec 22, 2005 | 08:57 AM
808_FairladyZ
No fibers, just soot and not that much of it, but it's there. Not a concern.
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
