Please Help Plenums
Old Dec 19, 2005 | 07:28 PM
glittle41585's Avatar
glittle41585
Default Please Help Plenums
Can Anybody Tell Me What The Differnece Is In Plenums. I Mean Is It Just The Upper And Lower Plenums And Which Is Better For Horsepower And $$$wise. Also What Is The Differnece Thanks
Old Dec 19, 2005 | 07:37 PM
glittle41585
Also What Is The Difference In The Sizes Like The 1/2 And I Think 5/6
Old Dec 20, 2005 | 03:46 AM
DavesZ#3's Avatar
DavesZ#3
cHECK oUT tHE mOTORDYNE aND aam wEBSITES. tHEY bOTH hAVE eXCELLENT wRITEuP oN tHEIR pRODUCTS (pLENUM sPACERS iS wHAT yOU'RE tALKING aBOUT):
http://www.motordyneengineering.com/
http://www.alteredatmosphere.com/
Old Dec 20, 2005 | 05:35 AM
If you read advertisements for plenums such as APS, APS gives you a complete rundown on faults of the OEM plenum, and improvements of the APS plenum. Give consideration that any advertisement is biased, and may not be 100 percent factual.
Old Dec 20, 2005 | 04:39 PM
glittle41585
what is the difference with the termo ones and which is better 1/2 or 5/16. is the aam either
Old Dec 20, 2005 | 05:49 PM
DavesZ#3's Avatar
DavesZ#3
The AAM spacer is actually tapered. The back end is 1/4" thick, the front is 1/2" thick. The front is where you want to increase the space to help get more air to the front two cylinders.
The "isothermal" part of the Motordyne kit is an insulating gasket than goes under the lower plenum to help keep the lower and upper plenum's cooler. Cooler plenum will result in a slightly cooler air flow into the engine.
allmycarsdie
May 13, 2016 04:38 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
