Kinetix SSV Possible idle problem
Old Dec 21, 2005 | 07:12 PM
plumpzz's Avatar
plumpzz
Default Kinetix SSV Possible idle problem
I just finished installing the kinetix SSV.. it has idle fluctuation.. it goes from 650 to 900 every 20 seconds or so.. not sure what it is. I checked all hoses and i tightened all the bolts.. i disconnected the TB but battery was disconnected.. I 'reset' the position i think using the method posted on the forums and it didn't help.. what to do?
Old Dec 21, 2005 | 07:16 PM
ZON's Avatar
ZON
Ummm, so you have a plenum AND a plenum spacer? And a change of plans too, eh. LMFAO!!
Old Dec 21, 2005 | 07:35 PM
plumpzz's Avatar
plumpzz
oop ahah.. i ment the thermal thingie.. I'll fix that about now
Old Dec 21, 2005 | 08:23 PM
plumpzz's Avatar
plumpzz
fixed! Loose coupling! Idles much better than before, surprised..
Old Dec 21, 2005 | 09:54 PM
TheLastSpartan's Avatar
TheLastSpartan
does the SSV change the engine note any?
any gains? ive heard a lot about the gains vs $$$ debate? tell me how YOU feel
Old Dec 21, 2005 | 11:23 PM
plumpzz's Avatar
plumpzz
Gains you can feel in the midrange quite a bit.. and upper.. it doesnt feel like the engine ran out of juice after 5k krpm any more.. i have a 287 hp engine. Lower, i felt no loss, no gain. Sound is like..more muscle car sound.... induction of air does that. It has the same affect on the sound as the JWT intake did, except not as ricey. its deeper and boomier, on and it whines in the lower rpms. Sounds good, pulls a lot harder than before. I like it, even if it cost me a fortune. Since it took 5 weeks to make, it didnt affect me as much... there was no..ok now its in...now what? effect..
Welds are awsome, nicely made piece...mandrel bent, stainless steel..it uses a special tool to install so don't loosoe it..uhmm thas about it. Oh it also negates the stock throttle body coolant warmer lines... so ur TB will be cooler definatley. Idles much nicer now than stock. There was a **** load of JWT oil in my stock plenum lol. From when i reoiled the filter.. :-D
BTW, the instructions blew, if you need help installing it PM me. It was a PITA to get in cuz its a tight squeeze.
Old Dec 22, 2005 | 05:25 AM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Please post pix ... thanks !!
Old Dec 22, 2005 | 06:33 AM
plumpzz's Avatar
plumpzz
Idk how..i have them on my camera..
Btw those pretensioners on the stock strutbar are a ***** to get right. It took me like 30 minutes to figure out how to use it and then another 30 to make it so i can close my hood and not hit the kinetix.
Old Dec 23, 2005 | 11:09 PM
plumpzz's Avatar
plumpzz
Pictures of it installed. Looks good.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
