CEL Fix?
Old Jan 2, 2006 | 07:52 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default CEL Fix?
I just ordered a set of APS Test pipes and heard al lot of ppl saying they have a CEL all the time. Was wondering who has tried the CEL Fix: http://www.*********.com/zwiki/Tutor...ith_Test_Pipes ? Anyone have pics of the parts needed or a DIY thread?
Old Jan 2, 2006 | 08:35 AM
The link is dead.
Old Jan 2, 2006 | 08:38 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I know... I can't fix it.
Old Jan 2, 2006 | 08:40 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
http://www.*********.com/forums/inde...873&hl=CEL+Fix
Thanks to Zivman for this simple fix.
If you are getting a CEL (check engine light) after installing high flow cats or test pipes, then you need this easy fix. No expensive 02 simulator is needed. They are more $ and more work than is needed. The HELP! method is tried and proven to get rid the test pipe related CEL.
Get two packs of HELP! Spark plug nonfoulers - part number 42002 or 42009 (either will work) - these are readily available at Autozone, Checker, Pep Boys, etc.
Drill ONLY 2 of the nonfoulers out with a 1/2" drill bit. Fit 1 NON-drilled fouler into each test pipe. Fit 1 drilled nonfouler into the previously installed undrilled fouler on each bank. Finally insert your o2 sensor into the drilled nonfouler and reconnect the wires.
THAT IS IT! Reset your ECU and the CEL will not come back!
Retrieved from "http://www.*********.com/zwiki/Tutorial:Stop_CEL_With_Test_Pipes"
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
