Help with non foulers
Old Jan 9, 2006 | 11:17 AM
thegr8one99's Avatar
thegr8one99
Default Help with non foulers
I've got directions to install the non foulers but i'm just not fully getting it.
Here's what I got.
Get two packs of HELP! Spark plug nonfoulers - part number 42002 or 42009 (either will work) - these are readily available at Autozone, Checker, Pep Boys, etc.
Drill ONLY 2 of the nonfoulers out with a 1/2" drill bit. Fit 1 NON-drilled fouler into each test pipe. Fit 1 drilled nonfouler into the previously installed undrilled fouler on each bank. Finally insert your o2 sensor into the drilled nonfouler and reconnect the wires.
THAT IS IT! Reset your ECU and the CEL will not come back!
Does any one have photos. It sounds simple but when your holding everything in your hand it just doesn't look that easy. Maybe i'm just an idiot.
Old Jan 9, 2006 | 01:24 PM
Zivman's Avatar
Zivman
Here's what I got.
it's VERY easy
Take one nondrilled nonfouler and screw into the bungs on each bank
Take the remaining two and dril them out with 1/2" and then screw them into the the first set you installed on banks
Now, install your o2 sensor and you are done.
Old Jan 9, 2006 | 02:50 PM
Interlago Fire's Avatar
Interlago Fire
how much are these non foulers?
Old Jan 9, 2006 | 03:21 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Couple of bucks
Old Jan 20, 2006 | 12:53 PM
anotheraznguy's Avatar
anotheraznguy
hi guys have a questions w/ the non foulers...
have the 42009 and it comes with a hole already drilled in there..
is that supposed to be right?
so 1 has a tiny hole and the other i drill out to 1/2 inch
if anyone can help me out that would be great
Old Jan 20, 2006 | 12:56 PM
Zivman's Avatar
Zivman
What you are describing sounds like you are on the right track
You need to use two for each bank, but you need to drill one on each bank out wtih a 1/2" drill bit to allow the sensor to sit in it.
if anybody wants these, I bought a few sets that I drilled out and are ready to install. I will sell them for 20 bucks shipped (for both banks)- all you need to do is pull your sensor, screw in the fix and reinstall your sensor. PM if anyone needs any
Old Jan 23, 2006 | 10:15 AM
anotheraznguy
sweet i installed this on an 05 and it does work..
didn't get any cel at all
Blurr350z
177
Apr 23, 2015 06:12 AM
jtgli
Aug 29, 2007 05:05 PM
pss350z
East Canada
Oct 28, 2006 03:20 PM
NIzzanturboka
Aug 12, 2006 09:35 AM
jedi-z
Oct 1, 2005 09:15 PM
