ssv manifold with gaskets
do i need new gaskets when installing my ssv, if so would a motordyne thermal gasket be the best option, or can i just keep the stock one??
sorry if this is a dumb question
your welx. The cork stuff sucks. Make sure to check for leaks when ur done installing..
PS.. make sure u seat the passanger side bolts in the manifold before putting the manifold on the block otherwise ur gonna have problems fitting bolts in there. Theres not enough room to stick them in. Seat them, screw them in a little and tighten in an alternating pattern like you would a wheel on a car (star pattern)
11-09-2020 10:27 AM
