Removing Stock Exhaust Bolts
Old Jan 14, 2006 | 12:30 PM
nsiege5's Avatar
nsiege5
Default Removing Stock Exhaust Bolts
I was just wondering if any has had to cut the bolts off their stock exhaust to get it out. My bolts are so rusted over and degraded that when I put a wrench to them they just went to moosh. Im thinking about taking a grinder and slicing them off so that I can remove my exhaust. Anyone have this experience???
Old Jan 14, 2006 | 01:18 PM
plumpzz's Avatar
plumpzz
how would slicing them off help any bit??? Try greasing them w/ wd40 a few times in a day and then try the next day. Also, try cooling them. Cold metal shrinks so you could be able to get it off a little easier.
Old Jan 14, 2006 | 02:12 PM
nsiege5's Avatar
nsiege5
Slicing them off would help because I can then take the bolt off and remove the pipe. The new exhaust comes with all new bolts anyway...
Old Jan 14, 2006 | 03:01 PM
plumpzz's Avatar
plumpzz
then how would u unbolt it out of the hole?? Sorry i never worked with uber rusted stuff..
Old Jan 14, 2006 | 03:06 PM
floored Z's Avatar
floored Z
I had the same problem when I installed my Borla. Ended up taking it to the dealership and just had them loosen them for me with an impact wrench and did the install at home.
Old Jan 14, 2006 | 03:37 PM
showstoppertk's Avatar
showstoppertk
yup, those bolts are a PITA. especially when your laying on the ground while reaching into the unknown and trying to gain leverage. all I can offer is more of the same advice. make sure everything is cooled down (maybe even spray some compressed air on the bolts for a bit), lube her up like its a ky-jelly party, and once you get your socket on their pull like your life depended on it (use a hammer to hit the end of the wrench if necessary). if all else fails you can either have a professional do it, in which case if it is really that bad they will probably just drill the bolts out or use a cutting torch. good luck.
Old Jan 15, 2006 | 08:11 AM
nsiege5's Avatar
nsiege5
Yea at least Im glad to hear others have found that their bolts are super f'ed up down there too. I will give it some good lube and if that doesnt work get out the titanium drill bits or the grinder and just cut those bad boys off.
Old Jan 15, 2006 | 08:27 AM
plumpzz's Avatar
plumpzz
OH ic, u'd drill them out :-D Yah..they're on SUPER tight on my car and its not even rusted. It took a 12 inch wrench w/ a 18 inch wrench attacked to it for torque, along with 100% effort from me, and i'm a big guy.
Old Jan 15, 2006 | 11:16 AM
Beeker's Avatar
Beeker
Exhaust bolts should really be removed with an impact gun. If you can't borrow one bring it to a shop and ask them to break the nuts loose with an impact gun. Then have them tightern them slightly with hand tools so the exhaust doesn't fall off on your ride home.
Old Jan 15, 2006 | 12:37 PM
Vamos_Rafael's Avatar
Vamos_Rafael
bro... you need air tools...
some WD40 and air tools got my exhaust bolt loosened up in like no time!
Old Jan 15, 2006 | 03:00 PM
CLETUS's Avatar
CLETUS
Default PB blaster is what you need
go to pep boys or where ever you buy parts and get some of this
best rust penatrant. period. soak the nuts for a minute or two then break them loose. air tools or a breaker bar will help tremendously.
good luck!!!
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Depravity
Oct 1, 2015 04:49 PM
Li1ag
Sep 28, 2015 02:07 PM
