Another MREV PLUS dyno ~22HP and 26 TQ
Old Jan 24, 2006 | 09:13 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by thawk408
Thats me . I dynoed on a dynojet with SAE corrected numbers. It is the same shop and same dyno that Doug from Crawford dynos on. My most recent dyno was 282.7rwhp and 252.8rwtq.
The TQ for the dyno posted looks really spikey for a dynojet. Why is that? Good gains tho.
EDIT: Hydrazine, do you have Andy's dyno to show? 291 is very impressive.
As far as the spikeyness of the dyno plot, I don't know why it is like that. I wasn't even aware they would be pre/post testing it. Rob at Z Car Garage performed the testing.
And no, I don't have Andy's plot. Maybe Andy can post it. I was there at the dyno day and he dynod right after RickDogg on the same machine. I was very curious to see Andy's results relative to Ricks because they nearly have the same type of mods and they both had a TS reflash to raise the revlimits. So it was a fairly good comparison. The only significant difference between the two setups was that Rick had test pipes and Andy had cats. Both cars were 292 HP and 291 HP respectively.
It wasn't until we installed the P&P lower collector that Rick was bumped up to 296. The P&P didn't add much "usable" power but it put the 4 HP right at the very peak of the curve.
Old Jan 24, 2006 | 09:21 AM
sq40's Avatar
sq40
tag
Old Jan 24, 2006 | 10:29 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I'd really like to see Andy's dyno plot as well to compare the whole rpm range to see the difference between the 287 motor and the revup's. I'd also like to see where his power peaked since we both have different rev limits with mine being 7100 and his being 7500. By looking at my dyno graph it looks like some timing advance past 6200 could help me a bit to keep the power strong or possibly extract 1-2 more hp.
One thing I really liked about what the dyno graph showed was that the PnP lower collector smoothed out that dip that normally occurs on our VQ's from 4800-5300.
http://members.***.net/speedjunkies96/dyno12105.jpg
Old Feb 12, 2006 | 11:45 AM
VQ35deMax's Avatar
VQ35deMax
ok so the mrev is swapping out the lower part of the plenum o nthe revup engine and puttign a lower part of the plenum form the 287hp? what is the mrev plus then? how would a mrev be with a plenum spacer?
Old Feb 12, 2006 | 12:06 PM
Hydrazine's Avatar
Hydrazine
Yes.
The same lower collector modified.
All MREV kits necessarily have the spacer included. Without a spacer, the highend would take a big hit. You wouldn't want it without one. The spacer is essentially mandatory if you want to do anything more than daily driving.
Old Feb 12, 2006 | 12:12 PM
VQ35deMax's Avatar
VQ35deMax
ok quick question then how much power and torque is gained with the mrev plus then over a stock lower plenum?
Old Feb 12, 2006 | 12:26 PM
Hydrazine's Avatar
Hydrazine
The title of this thread indicates what the the most recent independant dyno results were.
Old Feb 12, 2006 | 12:31 PM
VQ35deMax's Avatar
VQ35deMax
but isnt the graph for the revup motor? i am asking about the 287hp motor
is there gains when you take the lower plenum on a 287hp motor and swap it with mrev plus?
Old Feb 12, 2006 | 01:14 PM
Hydrazine's Avatar
Hydrazine
In that case you can essentially extrapolate the spacer gains on a 287 HP out to 7000 RPM to know what it does.
Conversly, you could extrapolate a 287 HP plot (without a spacer) out to 7000 RPM to get the idea.
Jason at Performance Nissan essentially did that same pre/post dyno plot a while back. And although the REVUP engine has variable exhaust cams, "most" of the power curve differences are driven by the different lower collector and higher redline.
Old Feb 17, 2006 | 04:02 PM
Hydrazine's Avatar
Hydrazine
Default One more dyno
Here is another set of dyno plots by Spencer over on the G35 driver board. Pre/Post dynos were taken without removing the car from the dyno.
Comments by 13bmx5 (Spencer):
The runs were made in 4th gear and they were "best ofs". The other runs were within a few hp or the torque numbers did not read properly. I did the install on the dyno, the car was never unstrapped. I did not do an ecu reset. My pulls were made to 7k on the tach inside the car, I did not let it hit the rev limiter. The only way the dyno will read 7k is if you let the tach read 7.3 to 7.5ish.
Area under the TQ curve says it all...
Attached Thumbnails Another MREV PLUS dyno ~22HP and 26 TQ-spencers-mrev-dyno.jpg
Old Feb 17, 2006 | 04:11 PM
k3silk's Avatar
k3silk
Haters.......dont be mad cause you only got 287 lol j/k who cares guys 300 287 not much of a diffrence besides the facts are head lights and tail lights look better then yours.
Old Feb 17, 2006 | 10:42 PM
brigz's Avatar
brigz
Just wondering, how does the Nismo CAI affect the powerband with this MREV+ installed?
Old Feb 18, 2006 | 04:37 AM
Havok_RLS2's Avatar
Havok_RLS2
Agree. I test drove an 06 because I had thought about trading up from my 05. Lets just say... I still have my 05.
Old Feb 18, 2006 | 07:31 AM
Hydrazine's Avatar
Hydrazine
The power band will have a little squiggle to it but in any case, HP and TQ will be shifted up as shown in the above plots.
Old Feb 18, 2006 | 11:21 AM
o snap its eric's Avatar
o snap its eric
im just jealous the rev'ed up motors are mod friendly
Old Feb 18, 2006 | 07:37 PM
Armitage's Avatar
Armitage
^The ironic thing is we're taking your lower plenum... lol.
But the CVT on the exhaust cam could be the difference maker. :shrug:
Old Mar 1, 2006 | 08:53 PM
rolling's Avatar
rolling
yea so there
Old Mar 1, 2006 | 10:37 PM
  #38
richardho11's Avatar
richardho11
wait, whats the difference between the 06 lower plenum and the 05? I have an 06' so why can't I use the stock lower plenum?
Old Mar 1, 2006 | 10:50 PM
  #39
Alang35's Avatar
Alang35
your stock 06 plenum is different from the 287 hp engines
Old Mar 4, 2006 | 05:35 PM
  #40
kittah's Avatar
kittah
will the mrev or mrev plus work on the 300 hp AT engines?
