Borla vs APS TD
Old Feb 11, 2006 | 12:06 PM
Madelinot's Avatar
Madelinot
Default Borla vs APS TD
Hi,
I've been lurking around for a little while and searched the site, but I can't find a real answer to the following questions. Between the Borla cat-back exhaust and the APS 2.5 True-duals:
1. Which is louder at idle and cruising ?
2. Which provide the best performance increase ?
3. Which has the best fit and finish ?
The APS is almost twice the price of the Borla, I just want to make sure it's really worth it... I have the APS TT kit on my G35 and high-flow cats (still have the stock exhaust).
Thanks a lot!
Old Feb 11, 2006 | 12:51 PM
plumpzz's Avatar
plumpzz
APS is QUIEEEEEEEEEEEEEEEEETTTT w/o test pipes. I mean, no one in my house knew i had an exhaust until i told them. Its deep and throaty at WOT however.
With test pipes theres slight drone in any gear at 2200 RPM. Its nearly silent w/ test pipes however from 2500-3000 RPM (cruising RPM's). After that it screams im fast.
Old Feb 11, 2006 | 01:03 PM
Diesel350's Avatar
Diesel350
If you have the APS TT kit already I would go with the APS TD.
Old Feb 11, 2006 | 01:59 PM
plumpzz's Avatar
plumpzz
Yeah if ur FI, forget borla..its too restrictive. Just skip to a dual 2.5 or dual 3 inch system.
Old Feb 11, 2006 | 05:13 PM
Madelinot's Avatar
Madelinot
OK, great feedback guys, thanks!
Old Feb 12, 2006 | 12:23 AM
Dubai's Avatar
Dubai
+1
APS for FI .. Borla for NA
Old Feb 12, 2006 | 12:32 AM
baptist's Avatar
baptist
You wont find better build quality than that exhaust, its the best Ive seen on a system.
Old Feb 12, 2006 | 12:33 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
1. Which is louder at idle and cruising ? almost the same
2. Which provide the best performance increase ? almost the same
3. Which has the best fit and finish ? Borla. Look nicer too.
I would recommend Borla over APS due to hp gain and pricing.
Old Feb 12, 2006 | 12:47 AM
JDMFairlady21's Avatar
JDMFairlady21
how about the fujitsubo legalis-r? any input about those? i've heard nothing but good things.
Old Feb 12, 2006 | 04:03 AM
Madelinot's Avatar
Madelinot
It isn't a true dual system and I think it doesn't look as nice as Borla or APS. It's apparently very quiet however.
Old Feb 12, 2006 | 07:36 AM
Zivman's Avatar
Zivman
Thanks a lot!
Don't even consider the borla. Get the APS and a set of test pipes. Just be aware that you may be in need of a retune, especially if you choose to get test pipes along with the exhaust
Old Feb 12, 2006 | 07:41 AM
Zivman's Avatar
Zivman
Probably true
Not even close once you consider he is running a TT setup
APS is a better fit and finish. Borla uses all slip joints and their exhaust piping is more prone to staining than the APS setup is. Go look at a Borla and an APS setup with a similar amount of miles on them and see for yourself. Beyond that, both use a similar OEM style muffler and tips so both look fairly similar from the back end
Poor recommendation considering the Borla is a N/A exhaust and the APS is a FI exhaust and the thread starter is a TT owner
Old Feb 12, 2006 | 07:43 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Borla is slip fit.....and can be prone to shifting around over time. APS, Injen and others are flanged
The question of what exhaust is right for you depends on how much power you are looking to make, what your budget is, and whether you want something loud, quiet, etc
Old Feb 12, 2006 | 07:44 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Originally Posted by Zivman
And the bubble^ goes POP!
Old Feb 12, 2006 | 07:46 AM
ARMSTRONGARMS
good luck i have neither but i would go aps since you already have their kit?
Old Feb 12, 2006 | 07:47 AM
Zivman's Avatar
Zivman
Originally Posted by idwin
trying to pop his bubble?
no
Just being myself
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
