Crawford manifold or MREV for the REVUP motor
Old Feb 27, 2006 | 01:50 PM
jcarp's Avatar
jcarp
its a new rev up motor with the shorter runners of the 287 worked over.
Old Feb 27, 2006 | 01:57 PM
jcarp's Avatar
jcarp
i've ran 8.5 in the eighth with timre spin.
Old Feb 27, 2006 | 02:04 PM
97supratt's Avatar
97supratt
Which spacer do you guys run with the MREV's, 5/16" or 1/2"?
Old Feb 27, 2006 | 02:16 PM
thawk408's Avatar
thawk408
The 300hp stock lower plenum has the shorter runners, not the 287hp. If you want to see a worked over lower plenum, here is Doug's. He polished the **** out of the top and gained 1hp if that.
Old Feb 27, 2006 | 02:38 PM
Diesel350's Avatar
Diesel350
5/16"
Old Feb 27, 2006 | 06:06 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Okay folks, I have a dilemma. I'm in the market now for a manifold my 06 REVUP motor and i'm not sure which route to go. I have seen all the awesome dynos on the MREV, but i've also seen great dynos on the Crawford. Does anyone have any experience with both? Please shine some light on this subject. The crawford manifold is a lot less than the MREV as well. I've searched and saw some dynos but nobody has really experienced both. Thanks
Arin
Hi Arin,
Why not try both on the dyno/street to see which will work best for you?
I have a cast plenum and MREV+ you can evaluate (no charge) for comparative testing if you like.
Tony
Old Feb 28, 2006 | 12:13 PM
jcarp's Avatar
jcarp
I Ported Open The Runners A Pretty Good Big For More Air Flow I'll Post Pics When I Get A Chance
Old Feb 28, 2006 | 01:36 PM
jcarp's Avatar
jcarp
Did Doug Port The Runners And Port Match The Gasket Do U Know?
Old Feb 28, 2006 | 04:05 PM
thawk408's Avatar
thawk408
I dont think so. There did not seem to be any point. You can port the runners, but the entrance hole to the heads is still going to be the same size.
Old Feb 28, 2006 | 04:11 PM
godmans's Avatar
godmans
Originally Posted by thawk408
I think the only difference is their 287hp lower plenum has the front runners cut down a bit. If it helps I can't see it helping a lot.
Did u just put the 287 plenum or the MREV+ ? I don't think if you can really compare a 287 plenum on a 298 motor with the one ported by MD..
Old Feb 28, 2006 | 07:12 PM
thawk408's Avatar
thawk408
Please explain why? The ported might help, but it will be so slim it probably wont even be noticed.
Old Feb 28, 2006 | 07:56 PM
Alberto's Avatar
Alberto
Cranky FI Owner
MREV all the way. I love my Crawford plenum on my 287hp motor, but that Crawford dyno posted should seal the deal for anybody with 1/2 a brain. The MREV have been independently tested at 15whp 20ft/lbs midrange, a few peak up top. An MREV equipped Revup vs a Crawford car the MREV would win hands down. I have installed 2 MREV's for local guys in the past 2 weeks the midrange is incredible, and the spacer keeps the top end lost by going to the smaller volumed lower plenum-also very easy to install about 1 hour. Remember guys-its the area under the peak that counts the most But what do I know, my Z is slow...
Old Feb 28, 2006 | 10:12 PM
97supratt's Avatar
97supratt
Originally Posted by Hydrazine
Hi Arin,
Tony
I might take you up on that offer. If the gains are that phenominal I am willing to buy.
Old Mar 1, 2006 | 06:56 AM
Hydrazine's Avatar
Hydrazine
15 HP "Minimum"
Old Mar 1, 2006 | 07:08 AM
Gooey's Avatar
Gooey
Hey im goin to MIR with my stock 06 revup and see how it goes on the track if alberto is still up for the deal wiht you im willin to donate the car for track uses
Old Mar 5, 2006 | 09:46 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by cnynracer1
Thank you for posting this dyno chart.
I would probably go with the crawford plenum after looking at your chart. Although the MREV does gain alot of power in mid-range, it looks like you hit a wall once it gets in to the high RPM powerband. I like the fact the Crawford plenum lost nothing down low, and only gained up top.
There has to be a middle-ground somewhere between these two.
But you will be slower than all the MREV guys. Remember the mid range power gain is so substantial that it will easily overcome a high rev engine. Why do you think Hondas are so slow. There power is only up high! Midrange power is what wins races.
Old Mar 5, 2006 | 09:47 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
What rpm do you guys shift your REVUP's at? All these dyno's I look at everyones shuttin down around 6500rpm. I drive this bad boy to 7200 before shifting and its working well.
I still shift at 7200. See my video...
http://www.sah2o.com/russ/videos/
2nd one is the better one. You really don't lose that much power up high at all. I had Stillen CAI, and MREV not the Plus yet, and 19" wheels with a full tank of gas when I did this.
Old Mar 11, 2006 | 02:04 PM
  #38
AboostedG's Avatar
AboostedG
Twin Spoolin
I have a dyno for that one too.
http://community.webshots.com/photo/...64805389GiVRUT
Green = Crawford headers, highflow cats, plenum, JWT intake, and borla exhaust
Red = Same as Green but swapped stock 300hp lower plenum for the 287hp lower plenum(so basiclly MREV with plenum instead of spacer)
Blue = Same as Red, but added Crawford Throttle body
From your chart, having the Crawford Plenum hurt your #'s w/ the MREV. Have you tried taking it off and use the MREV Spacer to see what #'s you'd produce?
I still don't understand what's the difference between the Mrev & Mrev+.
Old Mar 11, 2006 | 03:37 PM
  #39
eddie3782's Avatar
eddie3782
The 5/16 mrev comes with some spacers for the strut bar does that affect handelling or can you not even tell?
Old Mar 11, 2006 | 06:12 PM
  #40
Hydrazine's Avatar
Hydrazine
I know it can seem biased coming from the manufaturer but the strut bar spacers don't affect handling. The strut bar spacers are purpose built for the application. Solid 6061 T6511 Kaiser aluminum.
Once they are bolted down its completely ridgid.
